Remove_SMM... UEFI.
    Re: Remove_SMM... UEFI.
    Originally posted by mmccomputer View Post
    please need patched file
    I hope you know how to unlock it.
    Try ...
      Try ...
      a big thanks
        Originally posted by imranromi View Post
        i have all lenovo algorithm generate key so i use different algorithm solve my problem
        Sir i need this tool
          t540p patch key
          Hello together,
          I have forgotten the supervisor-password of my Lenovo ThinkPad T540p. I read a lot here in this forum and tried hard to clear the password on my own, but after disassembling my T540p, BIOS-modding and flashing, assembling again three times with no luck I hope someone of you can help me.
          Because of my T540p has two chips (MX25L6473E and MX25L3273E) I attached two dumps. Both dumps are made before my unlucky attempts to modify the BIOS on my own.
          Please, can anyone of you help me and do the hard job to modify the attached dumps?
          Thank you very much so far.
            Originally posted by bakar0345 View Post
            t540p patch key
            Hello together,
            Hello, you can either use Knucklegrumble Auto-Patcher.
            https://www.badcaps.net/forum/showpo...52&postcount=1
            Or you upload the 4MB file here and I'll patch it for you. (MX25L3273E)
            Only the 4MB file can be patched.
              who know how to patch T14 gen 1 with ryzen?
              Kill the state in yourself and you will be free like a wind...
                Originally posted by Maxpower3 View Post
                -------- Auto patcher with file selection V3 Version Mxp -------
                Special thanks to Knucklegrumble
                Only for Windows.
                Install
                LENOVO DXE Auto-Patcher v3.exe ("NOT MODIFY THE DESTINATION")
                and click on desktop shortcut.
                - support 32 and 64 bit
                - python 3.XX it's include in executable, no need install or configuration
                - Possibility to select your file directly
                - Auto-install with shortcut on desktop
                - Possibility of making several files in succession
                - With additionnal splashscreen
                Update V3 !! (read above)
                Only for Windows
                Fix problem with python
                Please Test and report
                  any solution for t14s with intel processor ???
                    Only for Windows
                    Thanks but it didn't work for me. Maybe because i use Win7?
                      python 3.9 isn't supported by win 7 may be
                      not tested 7 just w10 32 and 64
                        Originally posted by tienlk19 View Post
                        i follow the thread and was able to unlock my lenovo thinkpad yoga 11e 3rd gen. So here the files. Maybe could be useful to someone.
                        11e3rd_bios1.01passwordremoval.bin is for removing bios supervisor password
                        11e3rd_bios1.22 made from fl1 lenovo bios is for flashing after removing the password (or you can use your own dump)
                        good job, it has worked fine but you didn't detailled the process well
                          Thanks a lot
                            The file is patched too
                              My Lenovo X270 keep Entering Setup..., please help
                              I'm using LENOVO DXE Auto-Patcher v3.exe
                                this is the original bios file
                                  try
                                    Lenovo X280 W25Q128JV
                                    please
                                      try
                                      thank you, i have tried this file but still stuck in entering setup...
                                        Check if none of your key is stuck, making it to enter bios setup. Coz minor issues like this could make you nut.
                                        Last edited by YousefT; 07-22-2021, 05:23 AM. Reason: Stuck in entering Setup" I think it's still the bios issue. People with better knowledge will reply you I believe.
                                          please
                                          try it bro
