Dell latitude e5440 bios
  • dqtech
    Badcaps
    • Jul 2018
    • 630
    • N/A
    #141
    thanks
    • Azy
      • Jan 2024
      • 9
      • Pakistan
      #142
      Hey.
      I have a similar problem as most other users in this thread where the laptop takes a few seconds before the dell logo appears while booting. Additionally, when I power on the laptop, sometimes it basically does not turn on with the storage light blinking. I have to remove the battery and the CMOS battery to reset the bios, that helps it to boot again. Thought a bios update would fix these issues, but guess what, I can't do that either. the laptop fails to install the update and reboots back into windows rather than the update screen when installing the bios exe file from dell website.
      these problems have been plaguing my laptop ever since i gave my laptop to a repair center to reflash the bios because the laptop failed to turn on before that. the reflash however fixed the Wi-Fi problem i had before the reflash as mentioned by numerous people in the thread. Do note I bought this laptop used and have no idea if the previous owner has had it reprogrammed before or not.
      I'm planning on flashing the bios again but I'm pretty new to doing it myself, with this one being my first so I have a couple of questions.
      1. Can i simply flash any of the previously posted bios files in this thread?
      2. I'm planning on purchasing a CH341a programmer for this job. Will that work with this laptop?
      do note I'm still researching on this so any input will be helpful!!
      Best.
      Aizan T.
      Last edited by Azy; 01-17-2024, 04:54 PM. Reason: Figured out the type of Bios chips used and matched it to my laptop as well.
      • KLINIK ELEKTRONIK
        • May 2019
        • 43
        • indonesia
        #143
        Originally posted by SMDFlea
        Re: Dell latitude e5440 bios
        Try these,flash both .
        thanks wifi working
        • String2016
          • Nov 2015
          • 2233
          • philippines
          #144
          I need a working dell e5440, I tried all the bios here in this thread same problem turns on fan spins seconds off but light from the charger and wifi is blinking, I have attached the original backup
          and the SERVICE TAG 290HG12
          • Azy
            • Jan 2024
            • 9
            • Pakistan
            #145
            Had the exact problem when I flashed bios on mine but switching ram sticks/slots got it up and running again without any problem.
            ​​​​​​Do note I have two different speed ram sticks on my laptop, 1333mhz and 1600mhz. With just the 1600mhz ram stick installed, it had the same problem as you described. But installing just the 1333mhz stick got it running. Didn't investigate any further, hence don't really know if that had something to do with it or not
            • String2016
              • Nov 2015
              • 2233
              • philippines
              #146
              Azy you are right flashed with smdflea bios here and change the ram to 1333mhz now its working fine but both ram i have check in other laptop running thanks for the help
              • aijazali
                • 123
                • saudi arabia
                #147
                Hi all U1 U2 U7 128kb i got here but that is 256kb i attached backup laptop just power on 30 second then off no display i try many clean me i think 128kb problem coz this still not try kindly this file and work able if better
                Dell latitude E5440 rev 1.0 A00
                thanks
              • almussafer
                • Jun 2019
                • 71
                • Iraq
                #148
                Originally posted by Mr.dialogue
                Re: Need BIOS for Dell E5440
                here you go.....ok tested.
                work after 20 seconds thanks
                • almussafer
                  • Jun 2019
                  • 71
                  • Iraq
                  #149
                  its Work 100%
                  Thank you​
                  • Ziomal92
                    • Mar 2019
                    • 34
                    • Poland
                    #150
                    Please help me with clean ME Region. I tried myself but if i'm trying to open dump in FIT i got error. Maybe befor that i need to merge U1 and U2 ?
                      • 20781
                      You must post the service tag.Read: https://www.badcaps.net/forum/troubl...before-posting
                      • Ziomal92
                        • Mar 2019
                        • 34
                        • Poland
                        #152
                        service tag: CDFSYZ1
                          SMDFlea commented
                          Editing a comment
                          Posts merged with latitude E5440 thread. You do need to merge the 2 bios together before FIT will work.
                      • volinakis
                        • Jan 2021
                        • 2728
                        • N/A
                        #153
                        yep, you have to merge .bin files. Try cleaning merged file. FIT will split image in 2 files, write them both to chipsets.
                        • computerarena
                          • Feb 2022
                          • 7
                          • pakistan
                          #154
                          5440 vaw30 la-9832p rev:1.0 {a00} no display plz help..
                        • gkoukoul
                          • Mar 2017
                          • 19
                          • Greece
                          #155
                          Hello!
                          Laptop: Dell Latitude 5440
                          Board is: VAW30 LA-9832P Rev 1.0
                          S/T: 3CK2VZ1
                          It was booting and getting stuck at Dell logo, I couldn't even enter bios.
                          I flashed the bios from post #8 and now the fan spins after 30 seconds but no picture at all.
                          Attaching my original bios (8192 KB)
                          Can you help me please? Thanks!
                          • gkoukoul
                            • Mar 2017
                            • 19
                            • Greece
                            #156
                            Originally posted by gkoukoul
                            Hello!
                            S/T: 3CK2VZ1
                            I just flashed the two chips with the bios from post # 77 and it works!!!
                            • Kamlesh Soni
                              • Aug 2024
                              • 12
                              • INDIA
                              #157
                              Hello,Guys please help to clear me
                              VAW30 LA-9832P
                              Rev 1.0 (A00)
                              Doesn't POST, board ir taking 0.2 amps, fan spins and then board shuts off.​
                              • kalilinux25
                                • Mar 2018
                                • 2085
                                • ZAMBOANGA SIBUGAY
                                #158
                                VAW30 LA-9832P
                                Rev 1.0 (A00)
                                RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
                                Serial Number:
                                • Kamlesh Soni
                                  • Aug 2024
                                  • 12
                                  • INDIA
                                  #159
                                  Sorry for the late reply
                                  Sn : F19PL32
                                  • kalilinux25
                                    • Mar 2018
                                    • 2085
                                    • ZAMBOANGA SIBUGAY
                                    #160
                                    Sn : F19PL32
                                    here is your clean me region bin and rebuild and dmi added
                                    • gizaha
                                      by gizaha
                                      02-13-2024, 07:18 AM
                                    • jhanra
                                      by jhanra
                                      11-02-2024, 04:19 AM
                                    • TripTop
                                      Dell Latitude E7270 - Requesting BIOS clean/corrupt? service tag CB00KC2
                                      by TripTop
                                      Hi
                                      i have dell latitude E7270 with following symptoms:
                                      - takes long time to restart.
                                      - sometimes powers on and then off
                                      - sometimes while working it just dies,
                                      From googling online bios clean could possible resolve this?
                                      i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
                                      As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
                                      I reinstall...
                                      09-09-2024, 02:05 PM
                                    • mikeybass
                                      by mikeybass
                                      04-23-2025, 04:30 PM
                                    • Loli Popu
                                      DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
                                      by Loli Popu
                                      Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                                      12-13-2024, 08:29 AM
