Lenovo Ideapad 100S-14IBR BIOS
    Model: Ideapad 100S-14IBR
    Motherboard: 1501B_01_01 REV: SOVP4
    KBC: ENE KB9028Q
    Old BIOS:
    Re: Lenovo Ideapad 100S-14IBR BIOS
    salam
    try with this
      Didn't work, still won't turn on, 3V and 5V are present though. Could you please share EC as well
        You need to check and see if you have the rsmrst 3.3v S5 3.3 voltage also any external mouse or keyboard light up after you press power button. If you have secondary voltage and RSMRST AND S5 then bios is working .
        Techman1025
          Originally posted by ridamouh159 View Post
          salam
          try with this
          bump to this.
          i used this bios file and it worked, now when boots, has bios password
          any clue of the password?
          thanx
            What type of adapter do you use for this type of smd (25Q64FW)to read and write it with the programmer?
              did you sort the problem mate?
                I have same issue asking bios password
                  used ch341a with 1.8v adapter
                    still has password
                      Originally posted by el panke View Post
                      still has password
                      try..
                        Originally posted by peste View Post
                        try..
                        man u rules
                        tnahx alot for the file
                        works like a charm
                          try..
                          Thanks, works for me too
                            lenovo ideapad 100s-14IBR bios please
                            hi guys. is it ok to change the bios chip of the laptop coz i think my bios chip is broken. is it still working ??
                            KBC: ENE KB9028Q
                            Old BIOS:
                            hi. can i ask. is it ok to change the bios chip of laptop lenovo ideapad?? i need this bios but i think my original bios chip is broken. i want to try to change the bios chip but before first i wanna ask is if it's ok to change the bios chip since the other chip is also 8mb suppotted. thank u.
                            Last edited by SMDFlea; 05-30-2023, 02:21 AM. Reason: Moderator edit,merged 3 posts
                              Hi all
                              I have lenovo ideapad 100s-14IBR MODEL: 80R9 S/N YD01EZRX with password. I used dump from post 11 by peste to unlock it. It's ok but I have two problem after: the sound card is not available and the SSD port also is not available. I suspect that this bios dump
                              is not compatible with my mb. Please, someone can unlock the original bios dump that I will attach on this post. Thanks in advance.
                              Originally posted by razadom View Post
                              Hi all
                              try..
                                Hi peste
                                your bin is always locked
                                  Hi peste
                                  update winrar or use 7zip..
                                    man u rules
                                    works like a charm
                                    Works for me too, thank you very much.
