HP 15 bs DKL50 LA-E802P
    you can't write the bios chip correctly unless you remove it from the motherboard...you need an SPI programmer..here is a video as an example...https://www.youtube.com/watch?v=DWWigscuQDY
      Thank you for answering! I'll buy the programming tools soon. However, I don't have desoldering/soldering skills. I'll have to try out ch341a programming with soic8 test clip on the BIOS chip while it still is on the motherboard first.
        I managed to flash the Bios in system without removing the chip but the key was to feed external 3V3 (ch341B with test clip). Even though the circuit only draws 40 mA the 3V3 oscillate violently, so simply feed the 3V3 externally and you are good to go.
        I would also like to thank all the helpers from this forum. This enabled me to save my laptop myself after a failed BIOS update. I love fixing things and this forum is a gold mine. Keep it up, you're great.😍
          No Display Issue .Plz Solve
          Model hp 15-bs190od dkl50 la-e802p rev1.0
            hi try this
              I have a question, though I'm waiting for my programming tools to arrive in my country, my motherboard is an i5 8250u (15-bs1xx), can I flash any compatible BIOS variant regardless of motherboard model or id? I mean, 15-bs190od, 15-bs102nq, etc?
                no
                  If that is the case, to avoid flashing the wrong BIOS (I downloaded some here), can someone please share the correct BIOS for me?
                  model: 15-bs1xx dkl50 la-e802p rev 1.0
                  motherboard id: 832B
                  cpu: i5 8250u
                    Howdy!
                    I need BIOS for:
                    cpu: i5 8250u
                    • peste
                      peste commented
                      Editing a comment
                      Howdy!
                      I need BIOS for:
                      cpu: i5 8250u
                      post the S/N, post the original content of the bios chip, etc.
                      SMDFlea commented
                      Editing a comment
                      thread merged...........
                    Howdy!
                    I need BIOS for:
                    cpu: i5 8250u
                    HI try new file dmi add
                      Thanks for answering! How can I add the dmi file?
                      Here's my current BIOS configuration and lacks TPM Device, TPM State and other related settings (I got it using HP BCU)
                        https://www.badcaps.net/forum/troubl...22#post3497022
                          Sorry for not answering soon, I was trying to find a way to copy/dump BIOS bin without programming tools (I don't have them yet - late delivery due to civil unrest protests after political election).
                          Gladly enough, I found a way. Here it is
                            Now that I analyzed things thoroughly, that's not the current generic BIOS I'm using now that's the BIOS bin file update that bricked my laptop.
                              I need BIOS for:
                              model: 15-bs754tx
                              Part board : DKL50 LA-E802 Rev.1
                              Sn: CND8073DJC
                              thank you
                                Originally posted by daddyfix View Post
                                I need BIOS for:
                                model: 15-bs754tx
                                Sn: CND8073DJC
                                thank you
                                try post #6....08328
                                https://www.badcaps.net/forum/troubl...-0#post3496291
                                  Model 15-bs106na
                                  S/N: CND7487YGP
                                  ProdID: 3DK41EA#ABU
                                  RMN: TPN-C129
                                  Board model number: DKL50 LA-E802P REV 1.0 2017-06-23
                                  Chip BIOS: Winbond 25Q64JVSIQ 1743
                                  Problem: black screen after bios update
                                  Help me please 😢
                                    Originally posted by Antonio92 View Post
                                    Model 15-bs106na
                                    S/N: CND7487YGP
                                    ProdID: 3DK41EA#ABU
                                    RMN: TPN-C129
                                    Help me please 😢
                                    Thread merged with LA-E802P topic. What you have posted are the bios updates from HP support. What we need in order to help you is your bios backup from the bios chip on the motherboard. To make the backup you will need an SPI bios programmer.
                                      So I messed up, I flashed a BIOS I found online (DKL50 LA-E802P REV 1.0 2017-06-23 216-0867071 BIOS), the PC starts but the model, SN and everything else have changed, how do I make a backup if the chip has been rewritten? 🤦
                                        post the working bios
