Asus ROG GL502VM Bios help
  • AlvaroGuerrero
    • Aug 2018
    Hey I am trying to flash my bios to fix my computer but I am having trouble with my programmer/clip (CH341A Mini Programmer)
    I think i was able to read it and make a backup but for the life of me i cant write to the chip was hoping for some advice
    • 21932
    Re: Asus ROG GL502VM Bios help
    Your bios backup is corrupt.You need a bios dump that has a clean ME area . You bios revision is AS-SB .Theres a member on this forum that can help you with the bios - @cacla .
    • AlvaroGuerrero
      • Aug 2018
      thanks for the quick reply happy to finally get confirming that the bios was corrupt I think I found a older post with the correct bios dumps but if @cacla can help i would truly appreciate it
      https://www.badcaps.net/forum/showth...658#post843658
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • grimacelord
        by grimacelord
        07-10-2025, 02:52 PM
      • STKR123
        The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
        by STKR123
        Greetings badcaps community,
        I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
        So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
        Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
        I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
        These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
        I learned that desoldering...
        10-29-2024, 06:03 AM
      • throwaway327
        by throwaway327
        Model No: RC72LA
        Serial No: SBNVKD001014459
        06-18-2025, 05:52 PM
      • hotcrossedbuns999
        M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
        by hotcrossedbuns999
        My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
        1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
        2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
        3. I could only locate two chips that look like bios chips. Could someone verify this
        01-03-2025, 12:32 PM
