well you havent stated what the problem is, symptom or the history of laptop... you requested the bios, and bios i posted is ok. problem may be elsewhere
the problem began with a dead laptop. By replacing the IC power, the laptop is on. before I did all that, first my bios backup. after on normally, for some reason suddenly the laptop becomes no display.
before I do a more complicated job like reball pch, it's a good idea to flash the bios first. because before I got a case like that and succeeded in flashing bios with the original file from the official site.
There are 2 slightly different bios`es for this model.The EC has a few differences too.Its possible you might have had the wrong version flashed in the first place.
Try these bios and EC , flash both bios + ec from each.As ala_borbe said, if the bios don`t work the problem is elsewhere.
but there are differences in results between using the backup bios and other bios provided here. by using the bios of the backup or original from the laptop, when plugging the flashdisk, led on flashdisk blinking like a process is being run. if using other bios is not the case, led on flashdisk does not blink.
Well , @mcplslg123 cleaned your original bios, @ala_borbe gave you an official bios, and ive posted 2 bios straight from hp . What is the motherboard code , if its DA0U33MB6D0 REV. D then all the bios`es given to you by the members should have worked ,but only if the problem is with the bios.
