BIOS bin file for Dell latitude 7480
    Re: BIOS bin file for Dell latitude 7480
    Originally posted by TuanTongbadcaps View Post
    Try flashing the BIOS with the firmware extracted from another system to identify the firmware error and not spend a lot of time on it.
    thanks sir
      Please help, no display.
        Write your Device Service Tag.
        all donations are welcome,
          Originally posted by hardware1 View Post
          write your device service tag.
          599wgh2
            599wgh2
            Here's your New BIOS, try it and give me the results.
              Thank you, it's better, the dell logo appears, but I can't enter the bios. black screen appears after the dell logo. I'll check again tomorrow and let you know.
                Originally posted by okbalord View Post
                HI ALL
                I HAVE A dell latitude 7480 PW ON BIOS
                i need bios dump please for this one
                thank you !!!!!!!!
                try this
                  no change, after dell logo black screen, can you please clear ME?
                    There is a Admin PW in the bios file. Please remove. Service Tag: 4WMP4H2-6FF1
                    Thank you
                      Thank you
                      BIOS guides, methods, resources and tools
                      Password removal by laptop brand
                      27r2cXQyJ5jRGnkJ
                      xxX0rECbX0xV32nz
                      QWERTZ=NO
                      QWERTY=YES
                      Become a Badcaps supporter
                      Thanks to all supporters.​
                        27r2cXQyJ5jRGnkJ
                        xxX0rECbX0xV32nz
                        QWERTZ=NO
                        QWERTY=YES
                        Thank you!!
                          Thank you!!
                          You're welcome.
                          Please consider donation in support of the "Bios Requests" section of the forum.
                            Hi ineed un lock bios
                              There's no need to reflash the bios to remove the password for this model.
                              Use master password instead.
                                Hi ineed claer me
                                  Hi ineed claer me
                                  Did you read Vesko`s post, the easiest way is to unlock the bios using master password if the suffix is supported and not 8FC8, there`s no need to get a dump from another machine and then have to clean the ME firmware. By the way ,there`s an ME cleaning guide, try it -> https://www.badcaps.net/forum/showpo...41&postcount=3
                                  Also if you unlock the original bios the service tag and win key will stay the same
                                    Yes but this is other proplaem
                                      Bios test ok 100% no tag
                                        I HAVE THIS BIOS NO DISPLAY BUT I TESTED ANOTHER BIN IT WORK BUT NO WIFI
                                        AND BIP TO TOUCH KEY BEARD
                                        Please help, MY BACKUP
                                          Try this clean me file
