pls Bios HP Probook 450 G5
    Originally posted by hoaca388 View Post
    So you have accidentally damaged the motherboard, maybe lost capacitors or very small resistors around the bios chip pins.
    Right thanks a lot
      The BIOS is corrupted after an update (3 long beeps/2 short beeps).
      Here is the BIOS of the computer.
      Thank you in advance!
      PS: The motherboard is DA0XCMB6E0 rev:E
      Prod id 3GH65ET#ABF
      Oups, sorry.
      Here it is: 5CD85172BQ
        Originally posted by Yassoun75 View Post
        Oups, sorry.
        5CD85172BQ
        Become a Badcaps supporter
        Thanks to all supporters.
          5CD85172BQ
          Unfortunatly, same behaviour...
          What is the version of "your" BIOS?
          the same of the dump or the new one from HP website?
          Thanks.
            Thanks.
            Yes . it is latest.
              Yes . it is latest.
              Please, could you try with an older one?
              I think Windows update has flashed the Bios with the latest.
              It maybe this BIOS, the real problem...
              Thanks!
                HOLA AYUDA Contraseña del BIOS de la HP ProBook 450 G5 he probado otras BIOS y tarda demasiado en encender subo mi BIOS bloqueada
                HELLO HELP HP ProBook 450 G5 BIOS password I have tried other BIOS and it takes too long to turn on I upload my locked BIOS
                in English please..
                  post the S/N, the motherboard model, etc.
                    tried other BIOS and it takes too long to turn on, I upload my BIOS is locked HELLO HELP HP ProBook 450 G5 BIOS password I have tried other BIOS and it takes too long to turn on, I upload my BIOS is locked
                    HP Probook 450 G5
                    MDEL RTL8821CE
                    P/D DA0XCMB6E0 rev:E
                    S/N 5CD8085GKV
                      HP Probook 450 G5
                      MDEL RTL8821CE
                      S/N 5CD8085GKV
                      need both file
                        hello I have tested nearly 20 models of BIOS files, but in some of them only the orange light flashes and the device does not turn on, and in some other BIOSes, the device turns on but does not show an image and the fan spins fast. The BIOS of this device was already replaced by another repairman. and the original BIOS file is not available for me to upload
                        Please put a suitable Bios file for this device. Thank you
                        ProBook 450 G5
                        CPU: i5 gen7
                        VGA:onboard (intel)
                        DA0X8CMB6E0 REV E
                        ProdID: 4RJ92PA#ABJ
                        SN# JPH9172TVD
                          please clear me i have late display problem
                          I have an HP Probook G450 G5 that I deleted the BIOS password a few years ago, reprogrammed it and it works fine. What happened is that what I found on the internet said it was for that model, however when I enter the BIOS it tells me it is an HP Probook g470 G5. The problem I have here is that it takes a long time to turn on (HP logo appears) and most of the time it does not turn off, I have to force it to shut down. Images attached. Can you help me?
                            You MUST:
                            • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                              I have an HP Probook 450 G5 that I deleted the BIOS password a few years ago, reprogrammed it and it works fine. What happened is that what I found on the internet said it was for that model, however when I enter the BIOS it tells me it is an HP Probook 470 G5. The problem I have here is that it takes a long time to turn on (HP logo appears) and most of the time it does not turn off, I have to force it to shut down. Can you help me?
                              ProdID: 3YGO6UT#ABA
                              SN: 5CD8381GH1
                              MOTHERBOARD: DA0X8CMB6E0 REV E
                                hello
                                i have issue with hp probook 450 g5 DA0X8CMB6E0 REV E
                                freez hp logo
                                SN: 5CD904505Q
                                backup
                                  Originally posted by comprica View Post
                                  hello
                                  freez hp logo
                                  SN: 5CD904505Q
                                  backup
                                  hi try new file
                                    Originally posted by peste View Post
                                    Re: pls Bios HP Probook 450 G5
                                    Try..
                                    ITS SUPER WORKING ....Many many thanks
                                      HP ProBook 450 G5 with nVidia Graphics
                                      SN# 5CD9042PNY
                                      Hello seniors, one of my clients Brought me to fix his Laptop. I have fixed the Board, but someone else tried to fix it but failed, and they also changed the BIOS.
                                      Now it's showing the wrong SN #, and not showing the Graphics Card also. I am attaching Its DUMP as its not its own. Kindly someOne make for me .bin with the provided SN# plz.
