hi there , have this laptop for ages as it has a bios password , tried to find a dump file for it but no luck , DAX93AMB6G0 REV G , MODEL X93A ,TPT MV-0 20 E88441 94V-0 , anyone has this dump file?
hp probook 455 g4 dump file
Re: hp probook 455 g4 dump file
yes , it works fine , the chip model is 25B128CSIG, when i use "detect" on ch431a programmer shows memory type :GD25Q128 , using this config i could read the chip , erase , and write, but i get verifying problem "chip main memory with the contents are in disagreement" , now it gives the same led flashing after restoring the original dump file which i backed up, anyway to fix that?
Originally posted by layad View Postsorted , thank you, it was my mistake , i used now flashrom instead of the normal ch341a app
Originally posted by ribar96 View PostHello guys, I need help to get a new bios for my hp probook 455 G4
The marking of the motherboard is DAX93AMB6G0 REV :G
SN 5CD74597B4
Post what the problem is, be specific, - black screen, no boot, running slow, password.Do NOT post "clean me", "clear bios", "clean bios", "bios need" or other such terms
Become a Badcaps supporter
Thanks to all supporters.​
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..
Originally posted by ameerrrr View Postbios hp 455 g4 with DMI
DAX93AMB6G0 REV G
You MUST:- Read BIOS guides, methods, resources and tools
- Try the method at BIOS guides, methods, resources and tools before requesting help
- Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
- Use search function in case someone already answered your request
- Post under a related thread if it exists
- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
- Name your thread with make, model numbers and request
- Provide a BIOS/EC dump if possible
- Attach files directly to your post instead of linking to external websites
- Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
