hp probook 455 g4 dump file
    hi there , have this laptop for ages as it has a bios password , tried to find a dump file for it but no luck , DAX93AMB6G0 REV G , MODEL X93A ,TPT MV-0 20 E88441 94V-0 , anyone has this dump file?
    Re: hp probook 455 g4 dump file
    Post your bios backup.
      here you go
        Try this .
          after flashing the dump , laptop led (charger indicator) blinking all the time and the laptop is no turning on!!!!
            ok , flash this one, its the full bios straight from hp.
              still the same , flashing led
                @smdflea has very good experience in fixing bios and hp virgin bios should work. You said the laptop lying for long time. You got display before flashing bios??
                  yes , it works fine , the chip model is 25B128CSIG, when i use "detect" on ch431a programmer shows memory type :GD25Q128 , using this config i could read the chip , erase , and write, but i get verifying problem "chip main memory with the contents are in disagreement" , now it gives the same led flashing after restoring the original dump file which i backed up, anyway to fix that?
                    sorted , thank you, it was my mistake , i used now flashrom instead of the normal ch341a app
                      i need these program, i have problems with the 25b128csig and the ch341a pro, can you help me?
                        Hi, i have same password issue and i've flashed using all dumps above but not working for me. pls can anyone help remove password?
                          Both dumps contain password, can anyone help remove?
                            Hello guys, I need help to get a new bios for my hp probook 455 G4
                            The marking of the motherboard is DAX93AMB6G0 REV :G
                            SN 5CD74597B4
                              SN 5CD74597B4
                              Read the rules before posting:
                              Post what the problem is, be specific, - black screen, no boot, running slow, password.Do NOT post "clean me", "clear bios", "clean bios", "bios need" or other such terms
                              Become a Badcaps supporter
                              Thanks to all supporters.​
                                Oh, I'm sorry.. the problem is that when it turns on, the screen remains black, and the fan from the processor starts to whine more and more.
                                  thank a lot
                                    bios hp 455 g4 with DMI
                                    DAX93AMB6G0 REV G
