I need the HP zbook 17 g5 DUMP BIOS, thank you.
    Re: I need the HP zbook 17 g5 DUMP BIOS, thank you.
    Originally posted by tccyo22 View Post
    Ok it's stuck on the BIOS screen again and no further, can get "Entering Setup..." hitting F10 but it never gets further than that.
    I think it may have restored the previous one from the EC? Is this a thing with Sure Start models?
    EDIT: Little lookup on HP's website it says it keeps a copy in the HP Endpoint Security Controller which I think has restored some of the bad parts, is there anyway I can update this controller to prevent this data mismatch?
    Post EC here.
    Become a Badcaps supporter
    Thanks to all supporters.
      Originally posted by munir100 View Post
      i have hp zbook 17 g5 hag on log i try to me clean but not sceuefull hara is bios file
      Write down serial number.
        thanks for repaly see post no 20
          HP ZBOOK 17 G5 DA0XW3MBAH0 REV H Need bios Please
          Hello everyone
          Please I need This bios file (Main+EC) HP ZBOOK 17 G5 Board: DA0XW3MBAH0 REV H
          I don't have any old backup files because the device came to the workshop without a Bios chip
            Re: HP ZBOOK 17 G5 DA0XW3MBAH0 REV H Need bios Please
            Originally posted by Sami Wahid View Post
            Hello everyone
            Bios requests must now include the laptop serial number,please read the updated rules.
              Hello everyone
              S/N 5CD9383XNG
                I need bios Main+EC hp zbook 17 g5 da0xw3mbaf0 rev f ,s/n 5CD8099M1L, please help, thank you
                  i have a problem with my zbook 17 g5 laptop. The laptop turns on by itself. When updating to a newer bios, it no longer starts. Black screen and fans on full blast. I think iME is to blame. I have to upload a backup of the 32MB chip I created and everything almost works again. Here is a listing of both BIOSes. The BIOS was password protected. I used RCUnlocker. I have two of these laptops and they both do the same thing :-( Help me PLS
                    Vesko356 commented
                    Editing a comment
                    Thread merged.
                    Read the rules please.
                    You MUST:
                    • Post under a related thread if it exists
                    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules.
                  #29
                  DA0XW3MBAG0 REV:G sn: 5CD9037MXX
                    AAA
                      So after three days I managed to successfully update the bios to the latest version 01.26.00, but it's still not the same.
                      Sleep mode does not work.
                      LAN connection and cable disconnection functional only after restart.
                      Any change in the BIOS, save and the laptop won't boot again - the fans will spin at full speed and the screen will be black.
                      It does not show in UEFI mode the time until the battery dies, only when charging.
                      When turning off, the power button flashes 20 times and then the laptop turns off. Sometimes it turns itself on right away.
                      After disconnecting the battery and adapter, it will remain stuck in the HP logo. When I connect the LAN cable and restart it starts up ok.
                      Can someone please take a look at what could be wrong?
                      I am attaching a new bios listing with a new version. (DA0XW3MBAG0 REV:G sn: 5CD9037MXX)
                        HP ZBook 17 G5 Mobile Workstation IDS Base Model
                          Still the same.
                          After putting in your BIOS dump, there are three reboots with these screens and it's the same as before.
                            Still the same.
                            AAA
                              Now this again. Thank you very much for the effort, but I'm not up to this.
                              I'll throw him in silicon heaven.
                                test that two. flash both main and EC
                                  Hello hp zbook 17 g5 DA0XW3MBAH0 rev.H without bios main chip . I have only dump EC . Need main bios dump . Pls Help . Thanks !
                                  s/n 5CD936FJXV
                                    I have a zbook 17 g5 that is stuck in bios post.It reacts if i press f1,f2,esc and writes in the lower left corner the option chosen but nothing happens.I guess it's a bios error.
                                    Can anyone help me fix this ?
                                    i have the dumps here from bios and EC
                                    also the laptop does not have the SN on the case as it misses the tags from the case and covers
                                    • peste
                                      peste commented
                                      Editing a comment
                                      merged post..
                                    #39
                                      The laptop keeps stalling in the same place.
                                      This happened after a bios update.
                                      It does not freeze,but it looks like it waits for a signal or something is returning an error but does not ouput it.
                                      I've tried to remove everything removable and replace the ram aswell.I don't have a GPU to test with another one,but this one at least outputs video...
                                      Any suggestions ?
