Need bios asus gl553vd
  • mk praveen
    • Aug 2014
    • 33
    • india
    GL553VD bios please....
  • cacla
    • Apr 2015
    • 442
    Re: Asus GL552VW rev 2.0 Bios Need
    Here it si
    • mk praveen
      • Aug 2014
      • 33
      • india
      Thank you sir
      • qonma
        Kuli Solder
        • Jun 2017
        • 184
        • INDONESIA
        Please help
        need bios asus
        gl553vd rev.2.0
        problem no display
        thankyu very much
        • peste
          • 12729
          • ROMANIA
          Re: Need bios asus gl553vd
          https://www.badcaps.net/forum/showthread.php?t=66398
          • gracia
            • Feb 2018
            Originally posted by qonma
            Please help
            need bios asus
            gl553vd rev.2.0
            problem no display
            thankyu very much
            File is uploded here
            • qonma
              Kuli Solder
              • Jun 2017
              • 184
              • INDONESIA
              thankyu very much my bro
              • qonma
                Kuli Solder
                • Jun 2017
                • 184
                • INDONESIA
                Originally posted by gracia
                file is uploded here
                tenkyu very much my bro
                • nyknemesis
                  • Aug 2012
                  • 85
                  • romania
                  thank you,
                  it works but you have to clear me because it takes 30 seconds to start.
                  anyway thanks alot
                  • peste
                    • 12729
                    • ROMANIA
                    try...
                    • qonma
                      Kuli Solder
                      • Jun 2017
                      • 184
                      • INDONESIA
                      solved
                      • qonma
                        Kuli Solder
                        • Jun 2017
                        • 184
                        • INDONESIA
                        Originally posted by peste
                        try...
                        thankyou we try first
                        • qonma
                          Kuli Solder
                          • Jun 2017
                          • 184
                          • INDONESIA
                          try...
                          am sorry stil no display
                          • qonma
                            Kuli Solder
                            • Jun 2017
                            • 184
                            • INDONESIA
                            solved
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              solved
                              Whenever a case is solved then you should have the couertsy to help others.
                              • Babouk
                                • Apr 2020
                                • Austria
                                Hello, i have the same problem - no Display
                                @gonma - How did you solve it ? Thanks
                                • bilen
                                  • Aug 2014
                                  • 632
                                  • istanbul
                                  Asus GL553VD REV 2.0
                                  Problem no screen.
                                  please clear me org. dump.
                                  org dump:
                                  • peste
                                    • 12729
                                    • ROMANIA
                                    Re: Asus GL553VD REV 2.0
                                    orig+update site Asus
                                    • kodox
                                      • Jul 2017
                                      • 322
                                      • Indonesia
                                      solved
                                      how did you solved your problem?
                                      i had same problem here...
                                      • ezzeddin
                                        • Feb 2019
                                        • 16
                                        • syria
                                        how can do clear me ? for and bios file
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • grimacelord
                                          by grimacelord
                                          07-10-2025, 02:52 PM
                                        • throwaway327
                                          by throwaway327
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          06-18-2025, 05:52 PM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • MotherTeresa
                                          ASUS ROG GL552VW v2 - BIOS check/repair
                                          by MotherTeresa
                                          Hello Could someone who knows about BIOS take a look at the attached dump. Laptop AUSU ROG GL552VW with nVidia N16P 4GB and i5 CPU.
                                          I used to change GPU in the laptop, and it worked without problems for a few years. My 9-year-old daughter uses the equipment, yesterday it worked, today she says it won't start. I checked and it hangs on the ASUS logo, you can't enter BIOS (it worked once).
                                          Disconnecting all peripherals, including the keyboard, resetting BIOS with jumpers under RAM, changing RAM does nothing, it still hangs on LOGO.
                                          I installed a different BIOS from this model to...
                                          06-29-2025, 07:30 AM
