need bios for asus e402na rev 2.1
  • hamodeh
    • Dec 2017
    • 64
    • IRAQ
    hi
    i need bios for asus e402na rev 2.1 please
  • eikspaj
    N1NJ4W4RR10R
    • Mar 2015
    • 135
    • Philippines
    Re: need bios for asus e402na rev 2.1
    it would be cool if you can post the original bios....
    but try this
    There are 10 types of people in the world. Those that understand binary and those that don't.
    • lrservicios
      • May 2016
      • 130
      • espaƱa
      but try this
      This BIOS is not working, i have a passwored working BIOS here i attach
      • jdy
        • May 2019
        • 24
        • argentina
        I know a few years have passed but I need it and I did not find it here, I collaborate by leaving it, it works perfect at least on ASUS E402NA REV 2.3
        i think may work on other by his name "ASUS E402NA 304"
        • kalisko
          • May 2016
          • 45
          • Serbia
          Here's a brother
          • grefaldia
            • Jul 2020
            • 21
            • philippines
            please help me asus bios bin e402na rev 2.3
            need to this bios bin file because loptop is no display but have power.
            • kalisko
              • May 2016
              • 45
              • Serbia
              Here, let me help a little too
              This is a bios for the Asus E402N that works - it works OK !!
              MB: E402NA Rev. 2.1
              SR2Z7 N3350 processor
              Not the same as the one I sent in the previous post !!!!!!
              bios is OK, maybe someone needs that .....
              Greeting
              • coelectron
                • Mar 2014
                • 58
                • Argentina
                MB: E402NA Rev. 2.1
                Greeting
                No working, power on, but without video.
                • peste
                  • 13142
                  • ROMANIA
                  posts the original laptop bios
                  • AXY
                    • Jan 2022
                    • italy
                    Need ec bin file for asus e402na rev2.3
                    Hello everybody
                    i need ec bin file for programming io chip it 8995 on asus motherboard e402na rev2,3
                    thanks
                    • Rainbow
                      • Aug 2005
                      • 1375
                      I have Asus E402NA REV. 2.3 that's completely dead. No LEDs, not charging, not powering up. +5VA and +3VA are present. I've desoldered the flash and it's completely empty. Only FFh everywhere. Maybe the IT8995E-128 is empty too?
                        • 21403
                        What model is your programmer and software version. What part number is etched on the bios chip. Is the chip in the programmers support list
                        • Rainbow
                          • Aug 2005
                          • 1375
                          Flashed dump from ASUS E402NA.304.rar. Laptop powered up and boots! The EC internal flash is probably OK. Maybe it reads code from SPI flash.
                          • Rainbow
                            • Aug 2005
                            • 1375
                            The "dump" in ASUS E402NA.304.rar is the same as 304 BIOS from Asus website (minus the first 2048 bytes). WBT.exe does not seem to work. Do I need a real dump for that? Can WBT also set windows product key or should I use something other (UEFITool)? I extracted it from installed Windows.
                              • 21403
                              If you have a bios backup it can be copied to the new bios using a hex editor
                              • Rainbow
                                • Aug 2005
                                • 1375
                                No backup, unfortunately. The flash was blank.
                                I've downloaded two real dumps here - "E402N.rar" and "sus E402MA ORI.rar". They're versions 302 and 301 so they can't be compared completely. However, the differences reveal location of serial numbers and product keys - I'll probably just change them using a hex editor and copy the area to the new BIOS.
                                • Rainbow
                                  • Aug 2005
                                  • 1375
                                  To fully restore system IDs, the AsusGpnv region must be recreated (if it can't be copied from a corrupt BIOS). Start of AsusGpnv area (Base: 3E2000h) and size (10000h) can be found using UEFITool NE: Intel Image -> 2nd BPDT region -> Secondary BPDT -> OB -> AsusGpnv
                                  Also the BIOS from web has unlocked descriptor (replace first 4KB from some dump).
                                  AsusGpnv contains:
                                  • MAC address to show in BIOS - from the smaller sticker on the back of the board or from the network interface - it's stored inside RTL8402 (eFuse) and thus correct even with empty AsusGpnv
                                  • UUID - can be found in Windows registry - as a key in HKLM\SYSTEM\HardwareConf
                                  • some 12-digit number starting with 15, maybe some timestamp
                                  • machine part number (90NB0C5x-Mxxxxx format)
                                  • unknown BN09A or BN08 string
                                  • Windows product key
                                  • BIOS version (E402NA.304)
                                  • machine serial number (XXN0CV00V000000 format) - from the sticker on the bottom cover
                                  • board serial number (N0CV0000MB0000000 format) - from the bigger sticker on the bottom side of board
                                  If Windows is installed, search for MFG0 in pagefile.sys to find partial copies of the AsusGpnv area. Very useful for the 12-digit number, part number and BN09A/BN08 string as they don't seem to be available anywhere else.
                                  I've created AsusGpnv template (attached) from the dump in E402n.rar file - replaced the data by placeholders. The following script fills the template using real data - edit it first with your data:
                                  Code:
                                  #!/bin/sh
                                  # start of AsusGpnv area (Base: 3E2000h) and size (10000h) found using UEFITool NE: Intel Image -> 2nd BPDT region -> Secondary BPDT -> OB -> AsusGpnv
                                  cp AsusGpnv-template.bin AsusGpnv-filled.bin
                                  # MAC address (binary) - to show in BIOS (from the smaller sticker on the bottom side of board)
                                  # the real one is stored inside RTL8402 (eFuse) - it's correct even with empty AsusGpnv
                                  LC_ALL=C sed -i 's/MMMMMM/\x00\x00\x00\x00\x00\x00/g' AsusGpnv-filled.bin
                                  # 04 03 02 01 06 05 08 07 09 10 11 12 13 14 15 16 = UUID (01020304-0506-0708-0910-111213141516) - get from installed Windows - keys in HKLM\SYSTEM\HardwareConfig
                                  LC_ALL=C sed -i 's/UUUUUUUUUUUUUUUU/\x04\x03\x02\x01\x06\x05\x08\x07\x09\x10\x11\x12\x13\x14\x15\x16/g' AsusGpnv-filled.bin
                                  # unknown number, maybe timestamp (search for MFG0 in pagefile.sys)
                                  sed -i 's/NNNNNNNNNNNN/150000000000/g' AsusGpnv-filled.bin
                                  # machine Part Number (search for MFG0 in pagefile.sys)
                                  #90NB0C51-Mxxxxx = red
                                  #90NB0C52-Mxxxxx = white
                                  #90NB0C53-Mxxxxx = black
                                  # some part numbers found on web
                                  #90NB0C52-M00170 = F402NA-GA015T
                                  #90NB0C52-M00180 = L402NA-FA016TS
                                  #90NB0C52-M00480 = ?
                                  #90NB0C52-M00750 = F402NA-GA015T or E402NA-GA001T
                                  #90NB0C52-M02250 = ?
                                  #90NB0C52-M02880 = E402NA-FA021T
                                  #90NB0C52-M03090 = E402NA-GA167T
                                  #90NB0C52-M04280 = F402NA-GA208T
                                  #90NB0C52-M05110 = E402NA-GA248T
                                  #90NB0C52-M05850 = ?
                                  #90NB0C52-M06080 = L402NA-GA290TS
                                  sed -i 's/PPPPPPPP-PPPPPP/90NB0C52-M00000/g' AsusGpnv-filled.bin
                                  # BN09A or BN08 = ??? (search for MFG0 in pagefile.sys)
                                  sed -i 's/YYYYY/BN08\xff/g' AsusGpnv-filled.bin
                                  # Windows product key (get from installed Windows using ProduKey64)
                                  sed -i 's/XXXXX-XXXXX-XXXXX-XXXXX-XXXXX/00000-00000-00000-00000-00000/g' AsusGpnv-filled.bin
                                  # BIOS version
                                  sed -i 's/E402NA.VVV/E402NA.304/g' AsusGpnv-filled.bin
                                  # machine serial number (from the sticker on bottom cover)
                                  sed -i 's/SSSSSSSSSSSSSSS/XXN0CV00V000000/g' AsusGpnv-filled.bin
                                  # board serial number (from the bigger sticker on the bottom side of board)
                                  sed -i 's/BBBBBBBBBBBBBBBBB/N0CV0000MB0000000/g' AsusGpnv-filled.bin
                                  Script to replace descriptor and AsusGpnv in 304 BIOS (E402NA-AS.304.bin is E402NA-AS.304 from Asus web with first 2048 bytes removed, descriptor-from-dump.bin is first 4096 bytes from dump in E402N.rar):
                                  Code:
                                  #!/bin/sh
                                  dd if=E402NA-AS.304.bin of=part1.bin bs=1024 skip=4 count=3972
                                  dd if=E402NA-AS.304.bin of=part2.bin bs=1024 skip=4040
                                  cat descriptor-from-dump.bin part1.bin AsusGpnv-filled.bin part2.bin >E402NA-AS.304-modded.bin
                                  After flashing E402NA-AS.304-modded.bin, go to BIOS, load defaults and also provision the default secure boot keys. Finally upgrade the BIOS to 317 (using ASUS EZ Flash 3 utility in BIOS).
                                    SMDFlea commented
                                    Editing a comment
                                    Great job :-)
                                • razor_amd
                                  by razor_amd
                                  12-15-2020, 07:07 PM
                                • grimacelord
                                  by grimacelord
                                  07-10-2025, 02:52 PM
                                • jbonavita
                                  by jbonavita
                                  Some issues
                                  Things I tried
                                  04-29-2025, 09:38 PM
                                • throwaway327
                                  by throwaway327
                                  Model No: RC72LA
                                  Serial No: SBNVKD001014459
                                  06-18-2025, 05:52 PM
                                • lrouw84
                                  Asus vivobook s510ua bios changed to x510un
                                  by lrouw84
                                  Hi there,
                                  I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
                                  I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
                                  01-28-2023, 01:31 PM
