BIOS lenovo ideapad 330S-14IKB
    Marca: Lenovo ideapad 330S-14IKB
    Board model: 330S_KBL_v06
    winbond: 25064jvsiq1749
    the original since on the lenovo page is the update in .exe
    I need the original .bin to burn the bios again ...
    Thank you so much!!!!!
    Re: Se necesita BIOS lenovo ideapad 330S-14IKB
    try and report
      Originally posted by Claudiomfa View Post
      try and report
      Se grabo la bios y sigue muerta.... no carga no enciende... los voltajes llegan bien... supuestamente el dueƱo estaba actualizando la bios y se le apago..
      Lo raro es que con el .bin que me pasastes no lo pude grabar sobre el bios original ya que daba error... pero en un bios nuevo si lo pude grabar se probo sin resultados... el original se pudo hacer backup pero no se pudo grabar nuevamente....
        This is an english language forum,use google translate https://translate.google.com
        The bios was recorded and still dead .... no load does not turn on ... voltages arrive well ... supposedly the owner was updating the bios and turned off ..
        The strange thing is that with the .bin that you passed me I could not record it on the original bios since it gave error ... but in a new bios if I could record it it was tested without results ... the original could be backed up but not could record again
          Post your original bios dump and i will see if i repair them
          This laptop have kbc or secand bios chip?
            BIOS Lenovo ideapad 330S-14IKB
            Modelo: 81F4
            Modelo de placa: 330S_KBL_v09 REV MP
              Re: BIOS Lenovo ideapad 330S-14IKB
                original file 330s-1kib i5 8thgen
                  try and report
                  thankyou
                    lenovo 330S-14IKB No Display
                    lenovo 330S-14IKB
                    330S_KBL_MB_V09
                    Rev MP
                    P\N 431204237090
                    S/N PF1FUJAJ
                    No Display
                    Build Plss..
                      Lenovo Ideapad 330S-14IKB - Model 81F4
                      Model Name: 81F4
                      S/N: YD04VU18
                      Motherboard Label:
                      330S-KBL-I5-4G-4202811-5000-3453
                      P/N: 431204222050
                      BIOS Flash Chip: Winbond 25Q64JVSIQ
                      I wanted to clear the BIOS password that my son had added to his laptop (and had forgotten). After reading about clearing the Lenovo laptop BIOS passwords, it seemed that I should be able to dump the existing BIOS and then simply re-flash my BIOS dump back to the chip. I read that this process should erase the password as it is stored in a separate area of the BIOS chip that would be erased when flashing the existing image back to the chip.
                      I was able to dump the chip successfully several times using a raspberry pi 3 and Flashrom. I verified that all of the dumps were identical before proceeding. I re-flashed the chip with the same image and tried to boot the laptop. Upon turning on the laptop the white power LED at the top-right of the keyboard lights up white, but I have a black screen with no backlight, CPU fan will not turn on, & the CPU gets very warm. Power is provided to USB ports. After a minute or two the laptop turns off. Pressing the caps lock key does not toggle the caps lock light. There are no BIOS POST beeps.
                      Thinking that the original BIOS may have become corrupted I extracted the WinKabylake_m.fd flash file from the Lenovo BIOS update using Innoextract & InsydeImageExtractor. I copied my Windows Key and DMI info from my original BIOS image and inserted them into the extracted BIOS update image using HxD. After flashing this image back to the chip I get exactly the same result.
                      I have attached my original BIOS dump, the untouched BIOS update installer, and my altered BIOS update image file
                      Could someone please have a look at my BIOS files and see if there are any obvious problems that might be preventing the laptop from booting.
                      Thanks for your help
                        Re: Lenovo Ideapad 330S-14IKB - Model 81F4
                        Did you remove the bios chip from the main board ? If so, double check that you didn't accidentally blow away small components around the bios chip.
                        Become a Badcaps supporter
                        Thanks to all supporters.
                          bios extracted from the Lenovo site update
                          DMI 200000 - 20022F
                            Thanks, that was a good thing to check, but not the problem sadly.
                              DMI 200000 - 20022F
                              Thanks for the bios image, but unfortunately it didn't work. I guess I need to move onto finding a fault with the hardware that I must have created while removing the bios chip.
                                Re: BIOS lenovo ideapad 330S-14IKB
                                Hello Friends,
                                I lenovo ideapad powers on and powers off is seconds
                                330S-14IKB
                                can someone fix my bios.
                                All help will be very appreciated.
                                Thank you very much
                                  Originally posted by Atiq View Post
                                  Hello Friends,
                                  330S-14IKB
                                  Thank you very much
                                  you have everything you need at post #13...
                                    Thank you for your reply i tried #13 bios but only once display came again after restart problem repeated same.
                                      i Don't think it s a bios issue , try to post your problem here : https://www.badcaps.net/forum/forumdisplay.php?f=23
                                        thank you for your quick reply.
