hp 840 g6 6050A3022501-MB-A01
    Originally posted by vilmar27@hotmail.com View Post
    Please, could help me to remove the BIOS Password + Unlock the MPM for the below unit?
    System Board CT Number: PHWGH00WBDGT01
    SKU Number: 8QH17LP#AC4
    Serial Number: BRJ00000GT
    Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAcydUdpdqfPfXhKhkjhk8.Ya
    Build ID: 19WWCFBT601#SAC4#DAC4
    Best Regards,
    Vilmar
    Write only 16mb
      Originally posted by qayyum786 View Post
      try
      Thank you, the file worked fine
        Thanks a million Blaze Tech!
          Hi Blaze Tech,
          Please, only one more help. After I write the 16MB unlock bin file, I need to restore the factory defaults and/or restore security bios defaults after first boot or not?
          Tks,
          Vilmar
            HP EliteBook 840 G6
            SN: 5CG01464XX
            with bios Password and DeviceFreeze problem. thanks
              try
                it's working and no END POINT Security problem. thank you for the fast response...
                  Didn`t you try RCUnlocker ? https://www.badcaps.net/forum/troubl...=4#post1622423
                    I tried to find out but couldn't find a solution to the "hp endpoint security controller problem" error. without the original bios,,, I wonder if someone has been able to fix this error without the original bios?
                      Flash that both. be patient in first boot.
                        Sorry, I didn't tried. Never thought that RCUnlocker supported this model. What I was trying to avoid was the ENDPOINT SECURITY issue. But, after an hour "DEVICEFREEZE-1341" comes back.
                          do not touch the EC only flash this main. RC unlocker can only be used in 16mb chips EC. it cannot removed Absolute lock/ Device Freeze.
                          first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
                          use BCU. you can permanently disable Absolute lock in BCU.
                          here's your DMI:
                          Serial Number: 5CG01464XX
                          Product #/SKU: 7UA41UC#UUF
                          CT Number: PHWGH00WBDKLW4
                          Description: HP EliteBook 840 G6
                          BuildID: 19WWCFBT601#SUUF#DUUF
                          Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPhKhkjhk8.gn
                            still shows "hp endpoint security controller problem",,, this bios also reboots repeatedly for me
                              do you still have the original bios and ec?
                                This is the bios when I first read it (I saw it had been changed and didn't work)
                                sn :5CG04240VN
                                  sn :5CG04240VN
                                  flash the original EC and this main.
                                  here's your DMI:
                                  Serial Number: 5CG04240VN
                                  Product #/SKU: 7UA64UC#UUF
                                  CT Number: PHWGL00WBEC07B
                                  BuildID: 19WWCFCT601#SUUF#DUUF
                                  Feature Byte: 3X476J6S6b7B7H7M7R7W7m7saBaEapaqauawbUbhdUdpdqfPgShKj4jhk8.dt
                                    here's your DMI:
                                    The file doesn't turn on, the power light flashes continuously,
                                      here's your DMI:
                                      thank you for the file and effort... with regards to DMI i just input the data at BIOS SETUP-->MAIN-->SET MACHINE UNIQUE DATA, after entering all the required data this menu will become hidden. and for MPM i just kept on restarting the machine till it reach to "0".
                                        Hi, can you help, no power on ?
                                        HP 840 g6
                                        SN:5CG0091FTR
                                        I've tryed few EC + main from older posts, it's power on ,but with Endpoint problem. Can you fix my files ?
                                          HP 840 g6
                                          SN:5CG0091FTR
                                          CCC
                                          Become a Badcaps supporter
                                          Thanks to all supporters.
