hp 840 g6 6050A3022501-MB-A01
    Re: HP Elitebook 840 G6 Admin PW Help
    Originally posted by AudioGuy88 View Post
    I think you're right. The chip is IC25LP128 so it looks like the 16mb chip.
    Yes, it is.
    However there are no exposed feet/pads, so I can't solder wires onto it. I don't want to remove the chip to read/program it. Very annoying.
    But thanks everyone for their help
    The chip is WSON-8 type, so yes - you must desolder it from the board first, then use the suitable adapter to read/write the chip.
    Become a Badcaps supporter
    Thanks to all supporters.​
      Originally posted by Vesko356 View Post
      Yes, it is.
      The 32mb chip is also a WSON-8, but it had pads so I was able to solder wires to it and read/write it without removing it from the board.
      The 16mb chip however doesn't have the pads so I will have to remove it. But I don't have the adapters to read it.
      So instead of trying to remove the chip and reading/writing. I just want to break the laptop.
      I have wiped the 32mb chip, but after a few reboots the machine restores the bios again.
      What can I do to damage the laptop so it gets the motherboard replaced but not void the warranty?
        You can see where the traces go from each pinjust solder to the nearest point,resistor etc
          I've looked at that and I don't have the skills or equipment to do that.
          You can trace the tracks if you zoom in with a camera, but they lead to the smallest SMD I've ever seen, and I am not able to do that kind of work.
          I did use a heat gun and removed the chip. I soldered wires to but unable to read or write using the programmer.
          So the lesson is the HPs with 1 bios chip is fine and I can do those no problems at all ... the ones with 2 is way beyond my skills.
          Thanks again for your help everyone
            What model is your programmer
              CH341A I think.
              It's the cheap one you get from Aliexpress
                CH341A I think.
                NeoProgrammer, a good CH341A software alternative supports the chip - https://www.badcaps.net/forum/showpo...04&postcount=7 .Use the IC search,just type in 25LP
                  hp elitebook 840 g6 bios password
                  please unlocked my hp elitebook 840 g6 bios password
                    Re: hp elitebook 840 g6 bios password
                    Try this one and report back ...
                      Still asking for admin password
                        https://www.badcaps.net/forum/showth...ghlight=840+g6
                        My bad ,, read over here ... there is another SPI Chip ,, 16MB
                          also post the 16MB bios backup
                            Re: hp 840 g6 6050A3022501-MB-A01
                            please remove password hp 840 g6
                              try..
                                Ok i will test it and you would say it works
                                  hello friends, there was a bios password on my device, first I wrote the 32 mb password on the device, then I wrote 16 mb and 32 mb together. Is there a situation like this or anyone who can help? :ah:
                                    try..
                                      unlock tihs 840 g6
                                        Originally posted by jaouad0techy View Post
                                        unlock tihs 840 g6
                                        try ... you still have a 16MB bios chip on the board, look on both sides of the motherboard..don't forget to make a backup copy of the 16MB chip before writing..and replace it with what was sent ..
                                          Problem with elitebook 840 g6 bios
                                          Hello, i need to remove password Hp elitebook 840 g6.
                                          After trying to program with known good bios with org me region it works without password but hp endpoint problem shows on boot.
                                          Posting org dump files 32mb and 16mb.
