HP Probook 470 G5 DA0X8CMB6E0 BIOS X8C
  • bepom
    • May 2019
    • 8
    • bosna i hercegovina
    #41
    Re: HP Probook 470 G5 DA0X8CMB6E0 BIOS X8C
    fan spin full no video
    HP ProBook 470 G5
    with nvidia gpu
    can you help
    • hoaca388
      Badcaps
      • Jan 2022
      • 12330
      #42
      HP ProBook 470 G5
      with nvidia gpu
      can you help
      Is this your serial number : 5CD8420K6M ?
      • bepom
        • May 2019
        • 8
        #43
        yes
        • szabiika1111@gmail.com
          • Dec 2021
          • Magyarország
          #44
          Re: HP Probook 470 G5 BIOS request(repair or known good)
          Hello
          Did you manage to make the machine?
          What was the mistake?
          • Zeegee
            • May 2022
            • Slovenija
            #45
            Hello
            I need help with this bios , it is password protected.
            Can somebdy unlock it ?
            Zip file is bin file made by neoprogramer.
            Kind Regards
            • peste
              • Dec 2016
              • 13619
              • ROMANIA
              #46
              Originally posted by Zeegee
              Hello
              Kind Regards
              use RCUnlocker and unlock yourself..
              • dejanos87
                • Dec 2015
                • 26
                • slovenija
                #47
                Hello, can someone check the bios dump if it is correct? the laptop turns on, the caps lock blinks, there is no picture, the fan goes to full power after a while..
                please help
                • hardware1
                  • Sep 2021
                  • 2948
                  • N/A
                  #48
                  please help
                  Here's your New BIOS file, try it and give me results.
                  all donations are welcome,
                  • dejanos87
                    • Dec 2015
                    • 26
                    • slovenija
                    #49
                    I tested it, but now it doesn't even turn on anything, only the led blinks next to the DC connector :-( :-(
                    • dejanos87
                      • Dec 2015
                      • 26
                      • slovenija
                      #50
                      do we have any solution or some other dump file?
                      • dejanos87
                        • Dec 2015
                        • 26
                        • slovenija
                        #51
                        • hardware1
                          • Sep 2021
                          • 2948
                          • N/A
                          #52
                          Sorry, I don't have another option, maybe someone else can help you.
                          • pcbuddy247
                            • Mar 2018
                            • 4
                            #53
                            hi, could someone check/fix my bios pls. Laptop turning on, blank screen, caps and num flashing Checked the board, all seems good.
                            it's with nvidia chip
                            DAOX8CMB6E0 REV E
                            sn: 5cd8212wsm
                            thank you so much
                            • hardware1
                              • Sep 2021
                              • 2948
                              • N/A
                              #54
                              DAOX8CMB6E0 REV E
                              sn: 5cd8212wsm
                              thank you so much
                              Your dump file is messy try to read it again. Which Programmer and Software do you use? Are you using a clip/clamp or de-solder the chip?
                              • avs32
                                • Sep 2017
                                • Russia
                                #55
                                Originally posted by hoaca388
                                HP ProBook 470 G5 2RR73EA bios clear ME file.
                                Thanks, Friend
                                • huzo
                                  • Sep 2014
                                  • 187
                                  • CROATIA
                                  #56
                                  i tried your bios that you say is turning on,but no picture , it only blinks orange light to me... but all dumps i've tried only blink orange light...i was hoping at least mine would at least turn on as yours does...
                                  • javben
                                    • May 2013
                                    • 11
                                    • spain
                                    #57
                                    Re: hp 470 g5 -repair bios files needed
                                    Originally posted by SMDFlea
                                    Try this one, if it doesn`t work then flash the one by peste and enter the DMI manually.
                                    WORKING FOR ME AS WELL. THANKS SIR
                                    • boussaa islem
                                      • Nov 2018
                                      • 30
                                      • ALGRIA
                                      #58
                                      hi
                                      i need bios file hp probook 470 g5
                                      s/n 5cd9294n3x
                                      • boussaa islem
                                        • Nov 2018
                                        • 30
                                        • ALGRIA
                                        #59
                                        Originally posted by boussaa islem
                                        hi
                                        s/n 5cd9294n3x
                                        Bump
                                        • cesaro
                                          • Dec 2019
                                          • 28
                                          • N/A
                                          #60
                                          i need to unlock this bios please hp probook 470 G5 1LR91AV ,
                                          thank's
                                          • kenkaniff
                                            HP Pro x360 Fortis 11 inch G9 Doesnt boot after flashing bios
                                            by kenkaniff
                                            Product Name: HP Pro x360 Fortis 11-inch G9
                                            System BIOS: U94 Ver.01.08.00 10/06/2023
                                            Serial Number: 5CG31946F5
                                            SKU Number: 85W05EC#AK8
                                            Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
                                            This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
                                            I needed to remove bios password...
                                            10-01-2025, 04:32 AM
                                          • throwaway327
                                            by throwaway327
                                            Model No: RC72LA
                                            Serial No: SBNVKD001014459
                                            06-18-2025, 05:52 PM
                                          • ktcar214
                                            Need help for HP ProBook 445R G6 Secure boot key removal from BIOS dump
                                            by ktcar214
                                            Hello.
                                            I tried to add a custom secure boot key (for secure booting Linux) to my bios, but after this, my laptop bricked. After adding secure boot key (via PowerShell) and enabling secure boot my laptop turns on, shows HP logo, and after 5 seconds it turns off and on, and it repeats forever.
                                            My goal is to either turn off secure boot or remove my custom key from BIOS dump.
                                            I'll attach my bios dump (version R79_011700) from my bios chip 25b127dsig, my keys (PK/KEK/db), and bios dump from another HP ProBook 445R G6(I found it on this forum. URL: https://www.ba...
                                            12-07-2021, 08:57 AM
                                          • q2v5
                                            Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
                                            by q2v5
                                            Lenovo T480s
                                            Model 20L8-S3TE00
                                            Board ET481-U10
                                            Chip MX25L12873F
                                            Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
                                            2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
                                            The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
                                            08-15-2024, 10:40 PM
                                          • Neddsme
                                            Bios partially corrupted somehow and now warm boot doesn't work which is critical
                                            by Neddsme
                                            Hie.
                                            I own a Lenovo ideapad v310-15IKB with an i5 7th generation with only Intel graphics configuration.
                                            Now the heart of the problem is that I don't know when or how it happened but I suddenly started getting distortion in the graphics output on the LCD. This basically meant a black screen full of flickering multicolored short horizontal lines. This would happen 30-60 minutes after booting and using it normally.
                                            I run Windows 10 20H build so I thought it was just a Windows update issue or graphics driver outdated issue.
                                            I managed to run Windows troubleshooting and...
                                            02-04-2022, 05:57 AM
