surface laptop model 1769
  • ahmypc
    • Oct 2013
    • 80
    • Turkey
    #41
    Re: surface laptop model 1769
    Originally posted by peste
    try.
    Touch not working.
    • ajbernasko
      • Mar 2022
      • 229
      • ghana
      #42
      Please my bios dump gives me surface logo and then off. I replaced the iTE chip when there was a 3V short on it after battery replacement. I hope you help me, Thank you
      • ajbernasko
        • Mar 2022
        • 229
        • ghana
        #43
        Originally posted by ajbernasko
        Please my bios dump gives me surface logo for long. I replaced the iTE chip when there was a 3V short on it after battery replacement. I hope you help me, Thank you
        somebody please help me, Thank you
        • ahmypc
          • Oct 2013
          • 80
          • Turkey
          #44
          Surface Laptop 2 1769 M1088058-002 Need Bios file
          There is one for the 1st generation on the site, but I couldn't find one for the 2nd generation. It doesn't have its own original bios. I want to try with any compatible bios. Thanks.
          • iRiparo Malaga
            • Sep 2021
            • 5
            • Spain
            #45
            I have trying a lot of time to dump my BIOS without open my Surface Laptop 2. Finally i opened it and de-solder the chip and read with CH341a mini-programmer.
            I got the file, and look how to remove BIOS/UEFI password. Can someone help me to guess whats the password or clean the file?
            Thanks in advance.
            • peste
              • 13931
              • ROMANIA
              #46
              Thanks in advance.
              try...
              • iRiparo Malaga
                • Sep 2021
                • 5
                • Spain
                #47
                Hi Peste,
                After resolder the BIOS and test, when i push power button screen shows microsoft logo and go black, three times, after it auto shut down.
                I´m not sure about it is not well soldered or any problem with the new BIN flashed.
                Any idea?
                • peste
                  • 13931
                  • ROMANIA
                  #48
                  Hi Peste,
                  Any idea?
                  you probably read or wrote the bios with errors.. write back the bios chip with the original content and see what happens..
                  • iRiparo Malaga
                    • Sep 2021
                    • 5
                    • Spain
                    #49
                    After resold it works, but partially. Windows says that model of surface is "OEMLA SKU number i5" and serial number is "123123123".
                    When i download drivers, the setup says that is not for this model and abort the installation.
                    Therefore keyboard and other components does not work. I will try to extract the MSI packet.
                    It is possible to edit the BIOS to change the model? If you explain me i can try.
                    Of course, thanks for your work.
                    • iRiparo Malaga
                      • Sep 2021
                      • 5
                      • Spain
                      #50
                      Finally i could extract the .msi packet and get each folder with the drivers. Install .inf files in each folder, one by one, and ready, all works fine.
                      Really thank you for your help.
                      If its possible, could you explain what exactly modify in .bin file, in order to learn.
                      • mferna14
                        • Jun 2018
                        • 1050
                        Hi all., can someone please do a clean up of this MicroSoft Surface 1769 BIN file. Read from Original BIOS. The unit does not turn on, I see backlight come up & then goes back off. Thanks in advance
                        • hardware1
                          • Sep 2021
                          • 2951
                          • N/A
                          #52
                          Here's your Clean file, give it a try.
                          all donations are welcome,
                          • mferna14
                            • Jun 2018
                            • 1050
                            Thank you so much @hardware1, really appreciate, will try it today & inform you.
                            • mferna14
                              • Jun 2018
                              • 1050
                              @hardware1., I think it is working as I see that the problem is the same, I think there is something else wrong with the logic board., Today will start trouble shooting it. Thanks for the help.
                              • dahnking
                                • Apr 2018
                                • 265
                                • kenya
                                #55
                                Microsoft Surface Laptop 1st gen
                                display is on/off only microsoft logo 3secs
                                attached is backup
                                please help
                                • dahnking
                                  • Apr 2018
                                  • 265
                                  • kenya
                                  #56
                                  attached is backup
                                  please help
                                  Anyone to help on this????
                                  • Projectns
                                    • Sep 2019
                                    • 5
                                    can someone remove the uefi/bios password and clear me (is it necessary?)?
                                    Thank you!!
                                    • Projectns
                                      • Sep 2019
                                      • 5
                                      If its posible, would be cooool if also the me can clean.
                                      • Projectns
                                        • Sep 2019
                                        • 5
                                        Nobody who can help me ? :/
                                        • Projectns
                                          • Sep 2019
                                          • 5
                                          is that ok?
                                          • Loki_Fido
                                            BIOS for Microsoft Surface Laptop 7 - Model 2036
                                            by Loki_Fido
                                            Hi ya folks,
                                            Attached is the BIOS from a Microsoft Surface Laptop 7 - Model 2036
                                            As of right now i am unable to confirm whether this BIOS dump works or not.
                                            But i will update soon. Hopefully in a day or two.
                                            Given that no one else uploaded any BIOS backup for this laptop, I thought i might as well start a new thread and upload what i have.
                                            Microsoft Surface Laptop 7th edition
                                            Model 2036
                                            SN 0F3CPFB24153HH
                                            Remember, If you tried to read this chip with CH341A, this device will not identify this chip for you.
                                            Both ASProgrammer...
                                            09-11-2025, 04:00 AM
                                          • arber1232
                                            Bios for Surface Laptop Studio 2 Model 1964
                                            by arber1232
                                            Hi everyone i need help
                                            Have a Microsoft surface laptop studio 2 1964 that in unable to pass the surface logo.
                                            S/N: ofo1fze221900c
                                            Model: Surface Laptop Studio 2...
                                            08-15-2025, 06:07 AM
                                          • Benass
                                            Surface Laptop 3 Not Detecting SSD - Need Help!
                                            by Benass
                                            Hey everyone,
                                            I'm having an issue with my Surface Laptop 3, and I could really use some help. I've tried everything I can think of, but my laptop just won't detect any new SSDs I install. Here's a rundown of the situation:
                                            Problem:
                                            • My Surface Laptop 3 isn't detecting any new SSDs, including a Sabrent Rocket 2230 256GB NVMe SSD and a Dogfish 256GB M.2 2230 NVMe PCIe Gen 3.0 x4 SSD.
                                            • Both SSDs work fine in other laptops, so I know they are functional.
                                            • The laptop does detect a Forsee 64GB SSD from my Steam Deck, and I can successfully install Windows on it.
                                            What I've Tried:
                                            1. Compatibility
                                            07-22-2024, 11:26 PM
                                          • Loki_Fido
                                            Surface Laptop 7 Model 2036 Boardview
                                            by Loki_Fido
                                            Hi ya folks,
                                            Anyone happened have the boardview for Surface Laptop 7?
                                            Not Surface Pro 7. That is a tablet. This is a laptop.
                                            Laptop 7 got released in 2024. Still kind of new,
                                            Check your coat pockets folks, im sure one of us has a boardview to spare.
                                            Thanks in advance
                                            Happy repairs
                                            09-15-2025, 08:17 PM
                                          • User2025
                                            Please help to identify the components on Surface Laptop GO3, model 2013, i5-1230U
                                            by User2025
                                            I am working on a Surface Laptop GO 3, which is the new release 2024 with a i5-1230U processor. Originally, it had a 256GB SSD, then the owner attempted to upgrade it to 1TB SSD by himself. "Surprisingly", it did not boot afterwards, then changed back to the original SSD, did not boot either.
                                            It turned out to be that just a couple of components had been knocked off when the owner was trying to get off the SSD cover with his beloved screw driver.
                                            I do not have another board of same model. Although I have a Laptop Go 2, the layout of that bit...
                                            04-29-2025, 04:13 PM
