I need ACER Extensa 5230E working BIOS
  • bembeno
    • Feb 2016
    • 307
    • egypt
    pcb 07245-1M
    48.4z401.01M
  • peste
    • 12742
    • ROMANIA
    Re: I need ACER Extensa 5230E working BIOS
    post the original bios
    • bembeno
      • Feb 2016
      • 307
      • egypt
      the spi ic was damage
      • bachir2004
        • Feb 2015
        • 437
        • maroc
        Try this one.
        • titomno2
          Acer AN515-52 SATA1 port not working no hdd detected in BIOS...
          by titomno2
          Hi guys,
          On motherboard ACER AN515-52 type LAF951P.
          I fixed issue with not starting computer (it was the PQ201 component not working properly).
          But after checking everything I have still an issue with secondary SATA connector JHD1 (for HDD typically).
          Basically some HDD spin but are not detected by the bios.
          Already tried following:
          checked the 4 data lines
          #2 RDSATA_PTX_C_DRX_P4 => CO18 (10nF seems OK) => RO24 (0Ohm measured at 0.25Ohms).
          #3 RDSATA_PTX_C_DRX_N4 => CO17 (9.68nF seems OK) => RO23 (0Ohm measured...
          07-28-2024, 08:30 AM
        • verniumEN
          Acer Extensa 15 EX215-23-R7NG - BIOS, badly need help :(
          by verniumEN
          My laptop model is EX215-23-R7NG
          BIOS chip XM25QU128C
          Here is my original bin file, as well as how the BIOS chip looks like
          My situation is if I press my laptop power on, fan turns on for the first five seconds and turns off, no display (not even acer), but power indicator is on, and the CPU gets warm, even caught one time if powered on for long (before an hour) the fan turns on again, is it only right that I'm approaching via BIOS?
          Before I got into this situation, I was just watching movies, and while turned on, pressed the battery reset button and cleaned...
          04-21-2025, 02:31 AM
        • Amohac
          BIOS LOCKED ACER R753T-C1LK
          by Amohac
          Hi, I have an Acer Chromebook R753T
          with administrator lock. Could something be done in the BIOS. Attached is the “BIN” backup.
          Thank you.
          Computer:
          Acer Chromebook R753T-C1LK
          Mother: DA0ZCAMB8D0 NETWORK: D
          HSB J / 94V-0 / E89382 / 442 1/ MV-4
          Bios: WINBOND 25Q128JVPM /2139/ M138/ 42300
          16 MB
          Serial NO: NXA8ZAA0031501A1A87600
          SNID: 15010692076
          Model NO: N20Q10
          MFG Date: 2021/12/20....
          06-30-2025, 06:05 PM
        • ub6ib969
          Acer Predator PO3-650 BIOS can someone help convert .CAP to .BIN ?
          by ub6ib969
          Model Number: PO3-650
          Part Number: DG.BK4AA.006
          Serial Number : 33400117730
          BIOS IC : XM25QH256C
          I have uploaded the bios from the acer website and the extracted bios from the board. Any help would be appreciated...
          07-02-2025, 03:51 PM
        • String2016
          Acer Predator PH315-52 no display/black screen problem - need working bios please.
          by String2016
          I need a working bios on this acer predator
          MODEL:ACER PREDATOR PH315-52 54KC
          S/N:NHQ54SP00A024028992600
          SNID:02401039326
          Attached is the original bios no display problem black screen keyboard lights on...
          10-10-2023, 06:00 PM
