Bios dump request for Asus X554LA-XO496H X555LD Rev 2.0
  • Theworm
    • May 2020
    • 13
    • Italia
    Hi, I write here because I can't find a dump for my BIOS, if someone has a dump of [B] Asus X555LD Rev 2.0 X554LA-XO496H [/ B], can you share it with me?
    I have a CPU [B] Intel i3-4030U [/ B] I don't have a video card, I only have a video card integrated in the CPU, if you want more information about my motherboard ask and I will give you more information.
    [B] Thanks in advance [/ B]: crying:
    • 21692
    Re: Bios dump request for Asus X554LA-XO496H X555LD Rev 2.0
    Post your bios backup .
    • Theworm
      • May 2020
      • 13
      • Italia
      my backup and this I don't know if I did the backup well
      PS=I tried to flash the original file bin which in a post shared the dump bin x555ld rev 2.0 but when I turn on the pc it turns the fan but the screen is black
        • 21692
        Its not a full backup .Try again .
        • Theworm
          • May 2020
          • 13
          • Italia
          how can I recover the bios if I have no other backup or I no longer have the bios with the original data?
          i could try flashing this in bios and dump?
          Am I going to download the update from the official Asus website and then flash it in bios chips?
            • 21692
            Have you desoldered the chip or using a clip .
            • Theworm
              • May 2020
              • 13
              • Italia
              I had unsoldered the chip.
                • 21692
                What programmer ?
                • Theworm
                  • May 2020
                  • 13
                  • Italia
                  I used ch341A
                    • 21692
                    Try and read it again using ASProgrammer software - https://www.badcaps.net/forum/showpo...6&postcount=10
                    • Theworm
                      • May 2020
                      • 13
                      • Italia
                      ok i try with ASProgrammer.
                      here is my backup
                        • 21692
                        Try this bios .
                        • Theworm
                          • May 2020
                          • 13
                          • Italia
                          ok now i try
                          • Theworm
                            • May 2020
                            • 13
                            • Italia
                            Originally posted by SMDFlea
                            Try this bios .
                            i tried it won't turn on the pc
                              • 21692
                              Do you have any white/green stickers on the motherboard ,with the model number printed. X554LA ,X555LA or something else .
                              • Theworm
                                • May 2020
                                • 13
                                • Italia
                                the printed model and x554la-xo496h , motherboard x555ld main board rev 2.0 print white on green motherboard, on motherboard is x555-la print on stickers white
                                • Theworm
                                  • May 2020
                                  • 13
                                  • Italia
                                  what can I do?
                                    • 21692
                                    try .
                                    • Theworm
                                      • May 2020
                                      • 13
                                      • Italia
                                      try .
                                      now flash
                                      • Theworm
                                        • May 2020
                                        • 13
                                        • Italia
                                        try .
                                        I tried but it doesn't work, I turn on the PC and the fan turns and the screen remains black.
                                        • DynaxSC
                                          by DynaxSC
                                          06-14-2024, 03:49 PM
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • ArkzG
                                          [REQUEST] ASUS TUF A15 FA506NF (2021) - Clean BIOS dump needed (UEFI Password locked)
                                          by ArkzG
                                          Hey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
                                          What I currently have available:
                                          - Model: FA506NF (2021)
                                          - BIOS chip: GD25LQ16 (16Mbit/2MB)
                                          - Tools: CH341A programmer ready to use
                                          Does anyone have either a clean 2MB .bin dump of this model,...
                                          09-26-2025, 09:34 PM
                                        • kodox
                                          Asus ExpertBook B1400CB Bios Dump Needed
                                          by kodox
                                          need original bios dump, original bios has flashed by other technician before me.
                                          attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
                                          unit info:
                                          Model: Asus ExpertBook B1400CBA-0711A1235U
                                          S/N: R6NXNZ006657238
                                          CN: 7F6F
                                          Mainboard Code: B1500CBA R2.1...
                                          08-16-2025, 12:20 PM
