Latitude 7280 bios
  • aldopc
    • Jul 2017
    • 465
    • Chilito
    Latitude 7280 bios
    Hello friends, I need help please, I have arrived at latitude 7280, with a very slow start, it takes more than 1 minute for the dell logo to appear, check the bios chip (uc5) and I was intervened then remove the bin and clean the region, but it does not give an image with the region it cleans me, I tried 2 files from other computers that I have but none gives an image Does anyone have any ideas? Will I have to change the firmware of the other chip (ut6)? I leave my original file if someone can review for me.
  • peste
    • 12792
    • ROMANIA
    Re: Latitude 7280 very slow boot
    try..
    • aldopc
      • Jul 2017
      • 465
      • Chilito
      Hello Plague thanks, I have tested your file but it does not work the computer does nothing ... with the original file it turns me on what could it be?
      • lapfix
        • Mar 2020
        • 2721
        • my workshop
        Try this and give feedback
          • 20887
          The service tag is for a Latitude 7380 .
          • aldopc
            • Jul 2017
            • 465
            • Chilito
            Hello Smdflea, the service tag is G901QN2, the team came to me like this with the bios that I initially uploaded ...
            • aldopc
              • Jul 2017
              • 465
              • Chilito
              I have read other bios with live software serial number editor and it also shows that same service tag the lbe application is bad ...
              • peste
                • 12792
                • ROMANIA
                try..
                  • 20887
                  Dell Latitude 7280/7380/7480 with AMT
                  • aldopc
                    • Jul 2017
                    • 465
                    • Chilito
                    Ok, friends I appreciate your help I will summarize a little I have removed and installed the bios chip about 25 times, finally the problem was in the bios chip gd25q128, I replaced it with a windbond windbond 25q128, and the problem was solved, with the smdflea file turned on and asked for the servicetag when turning on, but it did not start from the bootmanager I did everything in the boot configurations I could even install the so, but it does not start, then I tried the second Plague file, this perfect fire and took the start the bootmanager right away only with the service tag of another computer, the same with the lapfix file, then I removed the file and with the serial number editor I changed the service tag for the one that is on the computer cover and it worked wonderfully, I sincerely thank you I was going crazy to all of you ...
                    • danito
                      • Jun 2016
                      • 922
                      I need a bios for the Dell Latitude 7380, I tried the sunshine version but it turns my latop into a 7280, meaning when I enter the bios it says 7280 ... I don't know what the difference is between them
                      Can you help me?
                      • feherhollo
                        • Nov 2019
                        • 110
                        • Hungary
                        Very hard to fix it. I have the same problem. You cannot mixed the bioses in 7280 models. You need same dump as your original board. Check your board dell part number and need exact the same part numbered dump to fix it. I have solved mine but was not as easy fix. If you have the correct dump you need to clean ME with the correct CSME 11 version.
                        You cannot mixed the xhip content also, I mean you need dump from an identical chip model also. There are extremely rare on the net dumps from latitude models. Lot of different revisions...
                        • George Babaianu
                          • Dec 2021
                          • 5
                          Re: Latitude 7280 bios
                          Hello.
                          Can any help me remove the Admin Password J5N0GH2-E7A8
                          Many thanks in advance !
                          • PowerAmpFreak
                            • 982
                            • Sweden
                            DELL Latitude 7280 bios request
                            Appreciate BIOS binary for DELL Latitude 7280.
                            The flash is a Winbond 25Q128JVSQ
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 11733
                              Re: DELL Latitude 7280 bios request
                              Post your original corrupt bios file here.
                              • pronto
                                • Mar 2019
                                • 116
                                • morocco
                                Dell latitude 7280 clear
                                hi every one can you clean me this bin bios of dell latitude 7280. thanks for help
                                • hardware1
                                  • Sep 2021
                                  • 2930
                                  • N/A
                                  Re: Dell latitude 7280 clear
                                  Here's your clean file.
                                  all donations are welcome,
                                  • pronto
                                    • Mar 2019
                                    • 116
                                    • morocco
                                    thank you friend bin its working
                                    • bilen
                                      • Aug 2014
                                      • 638
                                      • istanbul
                                      la-f311p rev 3.0 need bios dump
                                      latitude 7280
                                      service tag : F0BZ4H2
                                      orginal dump no screen
                                      • volinakis
                                        • Jan 2021
                                        • 2731
                                        • N/A
                                        Re: la-f311p rev 3.0 need bios dump
                                        Originally posted by bilen
                                        latitude 7280
                                        there are already threads open for Latitude 7280, next time use Search engine of this forum and DO NOT OPEN another thread!
                                        try clean ME
                                          DELL Latitude 7280 Notebook 7000 Specification for Upgrade or Repair
                                          This specification for the DELL Latitude 7280 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7280 boardview and 7280 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 7280...
                                          09-06-2024, 10:50 PM
                                          09-06-2024, 10:20 PM
