lenovo IdeaPad S145 bios needed
  • nick_rusev
    • Aug 2016
    • 10
    #481
    Hello , please help
    mb FV440 / FS441 / FS540 NM-C121
    rev 1.0
    This is the original file,won't start, help, please!lenovo IdeaPad S145 bios
    rev 1.0
    Flash power led?
    Lenovo Ideapad S145-15IWL
    MODEL 81MV
    SN PF1Y1ZCY​
    • hoaca388
      Badcaps
      • Jan 2022
      • 12350
      #482
      Originally posted by nick_rusev
      Hello , please help
      rev 1.0
      rev 1.0
      Flash power led?
      MODEL 81MV
      SN PF1Y1ZCY
      S145-15IWL Laptop (ideapad) - Type 81MV
      • nick_rusev
        • Aug 2016
        • 10
        #483
        • gnopa
          • Dec 2024
          • italy
          #484
          Hi guys, I need your help. After updating the BIOS directly from Lenovo tool, the laptop is not working anymore. It starts (led lighting, fan rolling) but has black screen even using an external monitor. As the only thing I've done was update the BIOS, I think the issue is there. I don't have a backup because I've used the Lenovo tool.
          Laptop: Lenovo S145-15IIL
          Board: GS44D/GS54D NM-C711 Rev 1.0
          S/N: PF1BFQZM
          Can anybody help me?
          • peste
            • 13661
            • ROMANIA
            #485
            S/N: PF1BFQZM
            you have everything you need at post #33
            https://www.badcaps.net/forum/troubl...e2#post3464664
            • gnopa
              • Dec 2024
              • italy
              #486
              Thank you peste.
              What about the data I should extract from the bios backupped?
              • peste
                • 13661
                • ROMANIA
                #487
                Thank you peste.
                you have the DMI range right there...
                • gnopa
                  • Dec 2024
                  • italy
                  #488
                  Yes, I've seen it but I don't have a backup. I've tried to save the current corrupted bios and for me it's just full of 0s (see attachment) and therefore I don't the other values to load. It's the first time I try to do these kind of things... 😅
                  • peste
                    • 13661
                    • ROMANIA
                    #489
                    The bios chip must be unsoldered from the board before writing or reading..
                    do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                    solder wires between the programmer and the bios chip..​
                    • gnopa
                      • Dec 2024
                      • italy
                      #490
                      At the end, I've managed to unsolder the chip and solder it back after have programmed it.
                      The laptop is now working again but I've an issue: the additional memory is not working. It's not a problem of the memory itself because I've also tried to use another working one and the issue still persiste. Could it be possible that the new bios is not supporting it?
                      • fabian14
                        • Jan 2021
                        • 26
                        • Colombia
                        #491
                        Model: 81W6
                        S/N: PF2G4NJM
                        Board: GS44D/GS54D NM-C711 REV:1.0
                        • peste
                          peste commented
                          Editing a comment
                          post merged..
                      • peste
                        • 13661
                        • ROMANIA
                        #492
                        Originally posted by fabian14
                        Model: 81W6
                        S/N: PF2G4NJM
                        you have everything you need at post #33..
                        • fabian14
                          • Jan 2021
                          • 26
                          • Colombia
                          #493
                          Thank you👍
                          • ric000
                            • Dec 2024
                            • italia
                            #494
                            backup lenovo s145.15. api .zip bios lenovo IdeaPad S145 necessario
                            pf14vfr5PF9XB9911013
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12350
                              #495
                              S145-15API Laptop (ideapad) - Type 81UT
                              • ric000
                                • Dec 2024
                                • italia
                                #496
                                I'll save it in the cip bios, I'll try it and let you know, thanks....I hope it works again
                                • ric000
                                  • Dec 2024
                                  • italia
                                  #497
                                  Thanks for the bios that worked, I found that the monitor backlight fuse blew - I installed Linux Mint with the additional monitor connected to the HDMI port. After a while the monitor turns off to restart it I have to turn everything off (Idealpad monitor cable completely disconnected from the motherboard) is this normal or is it a bios problem suitable only for with Lenovo IdeaPad S145 am I forced to use Windows 10???? can you change the bios can anyone help me I'm not very practical..... monitor message 0.9654191 integrity: Problen loading x.509 certificate -65 then starts linux mint LMDE 6 Faye.with Linx6.1.0.12 am64.... THANKS for hoaca388 and EVERYTHING
                                  • kobra
                                    • Feb 2016
                                    • romania
                                    #498
                                    Help please, Lenovo IdeaPad S145-15IWL
                                    Model Name (型號):81MV INPUT): 20V 2.25A
                                    SIN PE1DTNUK MTM 81MV004RRM
                                    Mfg Date: 19/08/22 Factory ID: JVHFCT
                                    Manufactured for Lenovo Made in China MO PF9XB9822006​
                                    power flash led problem, i have atached the backup from laptop, please help..
                                  • kobra
                                    • Feb 2016
                                    • romania
                                    #499
                                    thank you, on ur guide there was a link to the bios i need for S145-15IWL 81MV but i could find the post where...
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12350
                                      #500
                                      Here
                                      • joven016
                                        Lenovo Ideapad S145 need working bios HELP!!
                                        by joven016
                                        Problem is blinking power led only
                                        i don't know exactly if it's s145-15igm or s145-14igm
                                        have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
                                        Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
                                        Already tested some of posted bios here
                                        S145-14igm - success but invalid serial and not booting on OS
                                        S145-15igm - success with serial and some other info in bios but still not booting on OS
                                        already tried installing new windows but always booting on bios setup
                                        windows installer flash drive detected on...
                                        08-21-2025, 10:55 PM
                                      • mximiliandz
                                        help bios lenovo ideapad s145-14iil type 81w6
                                        by mximiliandz
                                        Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                                        06-20-2025, 06:50 AM
                                      • mkdj
                                        Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
                                        by mkdj
                                        Dear all,
                                        I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
                                        Here the steps I have taken to fix the laptop:
                                        - downloaded latest BIOS from Lenovo Website...
                                        10-18-2025, 03:43 AM
                                        Lenovo IdeaPad S145 Notebook S Specification for Upgrade or Repair
                                        This specification for the Lenovo IdeaPad S145 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S145 boardview and S145 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad S145...
                                        09-06-2024, 04:40 PM
                                        09-06-2024, 04:00 PM
