Hp probook 650 g1
    Hp probook 650 g1
    Hi for all,
    please I need a bios for this board 6050A2566401-MB-A04
    S/N : 5CG5200PXY
    I upload my backup
    thanks in advance
    Edit : i tried many dumps from badcaps and also changing bios Region with UEFITool
    Re: Hp probook 650 g1
    we wait your upload
      Originally posted by lapfix View Post
      we wait your upload
      sorry i was editing to add some informations
        Try and give feedback
        what's your pb !
          what's your pb !
          same state with your dump, all voltages are ok but no data on screen may be it is GPU issu
          I appraciate your help thanks a lot
            Try this please
              try..
                @peste @lapfix , The bios is L77. With FITC and ME 9 firmware you have to manually set the chipset if it defaults to HM87 and the chipset isn`t an HM87 .The 650 G1 has 2 different chipsets, HM70 and HM77 ,both those chipsets are`nt available as an option in FITC so set it to No emulation - Mobile , leave the other drop-down menu as 8 and 9 series .Set the boot guard profile to 0 - no_FVME .
                  Try with SMDflea recomandation
                    Thanks for all informations, the code printed on the chipset of this board is SR17D
                      HM87 , crap i was wrong . The boot guard should still be set to 0 though. EDIT: i was looking at the spec for the HP 650,not the 650 G1
                        @peste @lapfix not working for me Thank you for your efforts
                          No pb , i always learn something from you
                          @sourcebf , this one with your PCH
                            Sorry sourcebf ; try this one and not the one posted before
                              not working bro same problem. fan runs @ high speed. i have two same boards with same problem what to do
                                Change bios chip with last clean i post it
                                  chip is ok i think because it is flashing fine and detected by programmer
                                    any other suggestions, my brain is screwed due to this motherboards, i have been working since 2 weeks. but no use.
                                      Post your issue and the measurements you take in this topic : https://www.badcaps.net/forum/forumdisplay.php?f=23
                                        Can you try this one !
