HP 650 g5
    Re: HP Pro- Book 650 G5 help clean me region
    Originally posted by hardware1 View Post
    Try the files, hope it works fine.
    hey the 32 mb file works with quick display, but the challenge is it brings manufacture programing mode is in unlock mode 32 it keeps restarting with out any continuation while the 32 times keep on counting to zero.
    so the major problems are
    1. keeps on restarting
    2. manufacture programing mode is in unlock mode
    kindly help me clear the errors
      Re: 650 g5
      Hello!
      Can anyone help with what I assume is corrupted bios?
      Laptop originally booted fine,but had bios password which I tried to unlock. I soldered wires to the 32mb chip and tried to read it, unfortunately I forgot to disconnect main battery and laptop tried to power up while reading chip content. After removing wires from the chip and trying to power on laptop, it no longer posts, just fans spinning and no picture. ( I also realised that I neeed to use unlocker only on the 16mb chip, so I didn't need to mess with 32mb chip at all. )
      Later I desoldered both 32 and 16mb chips, read and saved the contents.
      If anyone can take a look at them and see if they can be fixed I would greatly appreciate it.
        Re: 650 g5
        hi i need remove password bios hp probook 650 g5
        6050A3028501-MB-A01
        thanks in advance
          Re: 650 g5
          6050A3028501-MB-A01
          thanks in advance
          First of all the dump is corrupted, what is your programmer?
          Secondly you've dumped the wrong chip. Find 16MB nand, dump the content, use verification and make sure you've read the chip properly then use RCUnlocker to remove the password.
          Become a Badcaps supporter
          Thanks to all supporters.
            Re: 650 g5
            thank you for resuming
            TL866II PLUS programmer
              Re: 650 g5
              6050A3028501-MB-A01
              thanks in advance
                Re: 650 g5
                6050A3028501-MB-A01
                thanks in advance
                Do you speak English?! I said - use RCUnlocker to remove the password:
                  Re: 650 g5
                  I have already try it and it didn't work
                    Re: 650 g5
                    Do it again, because I just used successfully the tool to patch your dump, and RCUnlocker do the job as it should.
                      hp 650 g5 bios password
                      Pleace help to unlock
                      Thank you
                        Re: hp 650 g5 bios password
                        Thank you
                        BIOS guides, methods, resources and tools
                        https://www.badcaps.net/forum/showthread.php?t=103526
                        3. Password removal by laptop brand
                        https://www.badcaps.net/forum/showpo...42&postcount=4
                          Re: 650 g5
                          Hello
                          I have aHp 650 G5 computer with the message of:
                          Hp endpoint security controller problem
                          You can be removed this message?
                            Re: 650 g5
                            Originally posted by josebml View Post
                            Hello
                            Ofcouse
                              Re: 650 g5
                              Hi
                              Is there someone who could remove the "HP endpoint security controller problem" from these dumps?
                              Thanks for your time.
                                Re: 650 g5
                                Originally posted by Dave Beck View Post
                                Hi
                                Compare the files at posts 72 & 73 with a hex editor or file comparison software
                                  Re: 650 g5
                                  Thanks for your help, the HP Endpoint warning has gone but I now have a slow boot due to ME Corruption.
                                  What is the best approach to solve the ME issue .. Bios shows ME Ver 0000.
                                  Thanks again for your time.
                                    Re: 650 g5
                                    Clear ME bios.
                                    https://www.badcaps.net/forum/showpo...41&postcount=3
                                      Re: 650 g5
                                      Help needed.
                                      Trying to get ME Analyzer to load the combined bin files from an HP 650 G5 and I get an error, same with the correct FIT. If I read a single chip Bios (HP 650 G2) all works fine so it must be the combined Bin file at fault. I made the combined file using the .bat script as detailed in the ME Firmware Cleaning Guide ... Any ideas ?
                                        help need unlock BIOS password HP 650 g5
                                        this is my dump
                                          Re: help need unlock BIOS password HP 650 g5
                                          this is my dump
                                          try this
                                          Model : HP Probook 650 G5
                                          SN : 5CG0197R84
                                          SKU : 5EG84AV
                                          BuilID : 19WWCOCT601#SUU#DUUG
                                          Board CT: PHWJU00WBDP20
                                          Featurebyte: 3X476J6S6b7B7H7M7QW7m7saBaEapaqauawbhcAdUdpdqfAfPhkk8.gE
