    https://www.badcaps.net/forum/troubl...-ec-pwd-bypass
      i am happly to use Autopatcher for Lenovo (BIOS password removal -16mb.bin), is there any patcher for 8mb bios file?
        Hello All...
        We have several P53 workstation laptops. On one of the laptops, a colleague has set a supervisor bios password that he cannot remember. How can this be deleted ? Currently this laptop is unusable.. of course we have an invoice for the device. The repair service suggested a motherboard replacement.. I am surprised... surely there must be another way to reset it..
        The machine won't even boot. It already asks for the password before. Do I have to read the eeprom contents ? I would appreciate if someone could describe the steps.
        Lenovo P53 workstation
        SN : PF2APA4Q
        MODEL: 20QNS0600
        Thank you..
          no patch via bios dump
          read NPCX897 or try bypass
          https://www.badcaps.net/forum/troubl...ss#post3237235
          https://www.youtube.com/watch?v=Xw28...nnel=M._.x._.P
            [QUOTE=Maxpower3;n3450270]
            /QUOTE]
            Do I have to solder the memory ? And have it read by a chip programmer ?
              thanks! i'll try this method
                Hi! I need help! There is a lenovo thinkpad 11e type 20g9-s05k00 laptop, m/b dali8emb8f0 with a supervisor password. On the motherboard IT8886HE and 2 flash: u24 bios 25q64fw amd u19 me 25q32fv. Can I remove the password in this way? Do I need to solder the flash drive for the programmer?
                  post your dump 64 and 32
                  and serial number
                  autopatch not work but try another patch
                    and serial number
                    system unit serial number LR06SLVA
                    systeem board serial number A1SH68J00AW
                      and serial number
                      which patch i can try?
                        try for test (just 64)
                        11e bios.zip
                        at restart : enter Bios setup with F1 and need clear security chip
                        type password blank and load by default and save
                        restore original Bios after...​​
                        if not work try autopatched
                          11e bios.zip
                          The first bios file is working, thanks, friend!
                            don't forget to put back the original file after cleaning,
                            otherwise no password forever
                              Hello. I have a Legion Y540 15IRH with BIOS locked with administrator password (machine boots, just no BIOS setup possible) and previous owner has forgotten what it is. Have been looking for solutions and not coming up with much, have dumped the BIOS and the machine uses ITE ec similar to Thinkpad and Ideapad models.
                              Are there any good options?
                                PLS UNLOCK PASSWORD
                                Lenovo THINKPAD X13 GEN 1
                                SN : PC-1PQ9W9
                                MODEL: 20T2S10H00
                                TQ
                                  fpt or dump bios
                                  read
                                  https://www.badcaps.net/forum/troubl...et#post3265798
                                    Hello
                                    can anyone help me with SVP
                                    Lenovo P52 20MA (S/N PF1MQ0ZW), Chip is MX25L25673G
                                      I patched bios and passed the section it asks supervisor password and I pressed any key, then 2x space etc.
                                      Now it`s stuck in "Entering Setup" section after I press F1, I also removed SSD before starting laptop.
                                      What can be the problem? Should I erase patched bios chip and put original default one from web or?
                                      Its X1 Carbon 20HQ
                                        Its X1 Carbon 20HQ
                                        restore original
                                          restore original
                                          You mean writing default/original bios of this model,right? Not the initial one I read & save at beginning before patch?
                                          Any X1 Carbon bios bin would be ok or 20HQ model level compatibility needed?
