LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
    Re: LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
    Originally posted by diappollo View Post
    Wow ! thank you for this quick feedback and (the anticipation of the questions)
    Sérial number : PF-2T7VT2
    so if I understood correctly, it doesn't happen at the bios level but at the "EC" level... what is that? I read the post carefully and I didn't see where the chip in question was located
    it's a big square chip next to bios and keyboard connector probably or on the other side
    maybe an ite8227e
      ok so the CH341A will be of absolutely no use to me for reading/writing the EC
      And still, if I understand correctly, there is no alternative to using a Vertyanov adapter? or maybe here: https://www.badcaps.net/forum/showth...=111439&page=2 with an RT809H but for a single troubleshooting it's not cheap. Or is there another solution that I missed?
        Originally posted by Maxpower3 View Post
        There are still things to do to finish
        It would be great if you could use the ThinkPad maintenance utility to bypass the password and use eeprom init to clear the EEPROM if the super administrator password was set
          Could this application even allow you to delete the password even for my model? I have the impression that it only works via a USB boot first and I cannot change the boot order... precisely because I do not have access to the bios, even this option is blocked. I imagine it can't be run on Windows?
            I don't know if you can help me by installing the patch on Lenovo L490 and the machine just beeps and doesn't show an image.
              You must post the serial number.
                I just want to post to say thank you to @Knucklegrumble for this great tool. Thank you very much.
                My ThinkPad T470s 20HF was bricked after recent BIOS update through Think Vantage from Lenovo. I can only see the keyboard lights flash and hear the CPU fun spinning after the failure. The screen will not light up. This was fixed by reflashing the BIOS using a new bought CH341a programmer and BIOS bin file from this thread.
                But it only takes me to the Supervisor Password enter page for BIOS setting. I am sure that my Supervisor password is correct. However, the system prompts error. After a few times of tries, I found this magic tool. I used this tool to patch the BIOS file downloaded from this forum and it worked. The Supervisor password was cleared and I could use my laptop again finally.
                Hope this information helps.
                Thank you all for this wonderful forum.
                  Need help to remove bios pass lenovo x1carbon 8 TH Gen.
                  Thx!
                  Original dump attached
                    Thx!
                    You must post the serial number.Read the updated rules.Havn`t you tried the Autopatcher ?
                      hi all , need help with a Lenovo T480 20L6S7PC1R - MB Serial L1HF89P01AV
                      Bios version # N24ET72W (1.47 ) - CPU Intel(R) Core(TM) i5-8350U.
                      need supervisor password removed
                      Thank you
                        Hello, i tried the autopatcher and i get no post (after patcher laptop power on, stay like that for 10 seconds then its start beeping, i followed all the instruction).
                        Sorry for asking without specifying what i tried, i dont have any ideea left except asking for help.
                          Thank you
                          Read the post above yours, the Autopatcher works on the T480 .
                          Please read the rules.
                            Clean the ME firmware on your original bios,sometimes that works.
                              When the PC gets tired of playing, it no longer even asks for the password yet still writes
                              Don't ask me, I don't know what I did, a few random conditional jumps
                                HERE IS YOUR FILE PATCHED
                                STEP 1: Flash given patch file (x1 carbon original_PATCHED)
                                STEP 2: Boot the machine
                                STEP 3: ENTER in to the BIOS settings
                                STEP 4: Enter 1234 when asked for Supervisor Password
                                STEP 5: Press enter when it shows Hardware ID
                                STEP 6: Press space bar 2x when asked
                                STEP 7: Turn off machine
                                STEP 8: Write your original BIOS (x1 carbon original)
                                STEP 9: Reset BIOS settings to factory default
                                  Please help me to patch bios for Lenovo P50s - after autopatcher 2.0 5 long beeps and black screen
                                      Supervisor pass removed, no need to use for any flash programming.
                                      Thanks for the help. I really appreciated all the knowledge shared in this forum and the persons here.
                                      All the best.
                                      AP
                                        I followed the steps, and it's worked with no problems, I've a lenovo thinkpad T440. Thanks a lot for your investigation, you save my computer!
                                          Hello
                                          does it work if i use dump patched from another computer on new computer ?
                                          for exemple, i dump old bios on an P71, patched it, worked well, can i use this patched file on another lenovo p71 ?
