LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
    Originally posted by bibi019 View Post
    Hi all i need autHopatced my locked dump file for lenovo yoga l390 i3 8 generaion model 20NUSW700 serial number R90XDGL6 i tried many patced file but always blask screen and bip music and some times te laptop power on and still locked wHen i put any keys code........
    emergency need file
    STEP 1: Flash MX25L12805D@SOP16 yoga l390 samir readed locked _20241104_172553_PATCHED.BIN
    STEP 2: Boot the machine
    STEP 3: Press ENTER or F1 /etc. to enter BIOS settings
    STEP 4: Enter any character when asked for Supervisor Password
    STEP 5: Press enter when it shows Hardware ID
    STEP 6: Press space bar 2x when asked
    STEP 7: Turn off machine
    STEP 8: Flash MX25L12805D@SOP16 yoga l390 samir readed locked _20241104_172553.BIN
    STEP 9: Boot the machine
    STEP 10: Press ENTER or F1 /etc. to enter BIOS settings
    STEP 11: Reset BIOS settings to factory default
      tHank you for your reply but file not working black screen and play music after flasHbios
        try
          Please help me unlock this T480S Bios Lock, i was tried patched tool but it still lock
            Patched check
              T480s stores password in EC, cannot unlock with autopatcher, only this method works https://www.badcaps.net/forum/troubl...-ec-pwd-bypass
                GREAT JOB.....THANKS YOGA 370 CLEARED .....NOW.......
                  Hi guys, i have T480 which does not patch with the software, i did used it with same model before and everything was fine. Any idea what caused it?
                    serial number ? https://www.badcaps.net/forum/troubl...before-posting
                      Originally posted by SMDFlea View Post
                      The posted BIOS it's a ThinkPad L480 with Intel(R) Core(TM) i5-8350U CPU @ 1.70GHz so the autopatcher works OK but I don't think this BIOS will work on a T480...
                      Click image for larger version  Name:	image.png Views:	0 Size:	20.1 KB ID:	3507395
                        That's correct. My mistake, laptop is L480, I don't have SN as laptops came as job lot, and they have mixed bases is there any other way to find SN?
                          Originally posted by danito View Post
                          try
                          tHank you te file wotked perfectely
                            Originally posted by jorgital
                            Hello All, would really appreciate any help/input: I tried to autopatch my T480 with locked BIOS and flash it but I get a black screen and a "melody" error . I flashed back my BIOS dump and the machine booted back as normal. Tried this routine twice with same results. Where did I go wrong?
                            Serial Number: PF1HFGMG
                            Product Number: 20L6S5NY00
                            BIOS Version: N24ET77W 1.52
                              may, first i have to read MORE the guide / rules
                              me having to the error "0199: Security System" - and need the Setup/BIOS with Supervisor Password.
                              And exactly this i forgot!
                              I already tried to do much things i found while searching before through many many forums.
                              Directly after turning the notebook on i enter the BOOT-ON pass in, this error appears, with F1 for going to BIOS - this error appears!
                              I have also a Lenovo Thinkpad T480 (knowing the Boot-ON password, but that doesn't help, cuz he wants for no other possibility the supervisor pw)
                              PLEASE guys, can somebody help.
                              I also find a pre-programmed BIOS chip at ebay, but the SUPERVISOR password is obviously saved in another place.
                              (removing the CMOS / BIOS battery will not work (notebook model is too new).
                              Also i have read the guide that would posted here often times...
                                There is a sticker on motherboard OR enter bios read only mode by simply pressing enter key when ask for password
                                  Can it be done with a pendrive or you need a clip-on chip reader of some sort? if the reader is needed can you give me a recomendation? i will probably use it only once i have a p51 to patch
                                    Hi, I have a Lenovo X390 Yoga, Type: 20NN-002AGE S/N: R90WZWSJ. I tried the auto patcher, but the laptop starts once, then reboots and beeps...doesn't post, if I put back the original BIOS it's all good again. What gives? I included the original and the patched BIOS.
                                    Try to buy this clip
                                    https://a.aliexpress.com/_EvoJWbL
                                      Originally posted by ezazuk View Post
                                      I have all of those clips and a Xgecu T48....
                                      Hm, so only bypass will work, I will try that then.
                                        Hi everyone, after running the patch on my dump, I start the computer but it remains stuck on the Lenovo writing, it doesn't let me press any key to access the bios, has this happened to anyone?
