Surface 4 Pro BIOS locked
    Re: Surface 4 Pro BIOS locked
    Originally posted by surface2023 View Post
    sorry but i dont know what i must make
    as peste said you have to read the content of bios chipset with a programmer and post it here.
      you buy a programmer... open the laptop... take out the bios chip from the board... read the content of the chip and post here... someone will delete your password... take the content from the website and write it back on chip...stick the chip back on the board...do a test...see if it's ok...and if it's ok...thank you and close the laptop case...and that's it..
      for example, you have a video at station #174...now you understand???!!!
        ok thanks for all
          I've been researching this tablet for a while now. I have a UEFI password locked SP4 but it boots to Windows fine just without admin access. Is my only solution to open up and dump bios and then reflash to reinstall windows and have full admin access again?
          It's too bad these are annoying to be opened, maybe I can find a repair shop in the area to do it
            yes... the only solution..
              Can you tell me wich programer i must bay for read my bios please
              Someone send me a link
                Originally posted by peste View Post
                try..
                Hello everyone, I tried but the tablet does not start
                  what did you try?? what's your problem?? post the original bios..
                    dump_surfacePro4.zip - original bios with password
                    dump_surfacePro4.new.rar - made by paste no password. I flash this bios but surface is not start. but if I flash original bios is start but password is here
                      @www111www
                      Try it!
                        Originally posted by fxreen View Post
                        @www111www
                        Try it!
                        I tried to flash but the tablet does not boot. only black screen
                          try this..
                            Greetings everyone... I'm new to the forum, however I took the time to read the entire thread, as well as all the attached links to avoid asking unnecessary questions.
                            Like the vast majority, I am here for the same reason, bios locked by password, so I am attaching my 16Mb .bin waiting for the collaboration of the wise experts for its modification, always thanking them in advance for the valuable work they do for all of us who come here looking for help.
                            I also leave a silly concern... Should I delete the IC and check before recording again?
                            I await your responses...
                              Can someone help me with this annoying password?
                                I never delete the bios chip before writing and I've never had problems...others delete it...
                                  Thanks... I test and report.
                                    dump with pass
                                    please remove
                                    thx
                                      Originally posted by danito View Post
                                      dump with pass
                                      please remove
                                      thx
                                      try..
                                        After flashing the new file it never turns on again, then re flash original file and it doesn't turn on either.
                                        Definitely the problem is not the IC, it's good, neither is the soldering.
                                        You might think it was a bad copy even though you did it with three different programs and they were all the same.
                                        The flash was done with AsProgrammer_2.0.3a from CH341A with 3.3 Volt mod since CH341A Programm and NeoProgrammer couldn't unlock the write or maybe I didn't know how with those.
                                        SP4/1724 - I5/8Gb/128Gb
                                        Any suggestions that might help would be welcome?
                                          Ok... I forgot comment the model of motherboard: x911788-009 i5 8GB 256GB
                                          Does anyone have an original dump of this model that I can compare and test?
