Need UEFI Password Removed from my Surface Pro 5 BIOS DUMP
    Re: Need UEFI Password Removed from my Surface Pro 5 BIOS DUMP
    Originally posted by gnoozle View Post
    please remove password
    Test and comments.
      Originally posted by aldopc View Post
      Test and comments.
      thanks bro it work . thanks
        Hello All.
        Would someone be able to help me with removing the system password from my Surface Pro 5 1796 please? SN: 023447182053. Board number: M1007506-015. If someone could point me in the right direction I would be so very grateful. I don't understand the AWORD thing?!
        Thanks in advance
          Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
          as in RULES
            Originally posted by volinakis View Post
            as in RULES
            Done. Can you help?
              Originally posted by Landy110 View Post
              Done. Can you help?
              try this
                please remove me bios password Surface pro 5
                MODEL: 1796
                IC: 3048A-1796
                motherboard: M1007506-015
                  MODEL: 1796
                  IC: 3048A-1796
                  serial number ??
                    Originally posted by minhdigital View Post
                    serial number ??
                    068922184853
                      068922184853
                      Send to you, try, Merry christmas !!
                        The password has been removed successfully thank you
                        I have another device with the same specifications
                        Does the first file work with it?
                        SN 072132684853
                          SN 072132684853
                          Send to you, First file not work with it !!
                            It works successfully Thank you very much
                              Hello, can someone help me with the bios, the surface shows the logo for 2 seconds and the screen get black.
                              Surface pro 5 1796
                              SN: 008793174853
                              • ukpicasdo
                                ukpicasdo commented
                                Editing a comment
                                Hi. Did you manage to fix the problem with this new bios file? I am hoping it is fixable.
                              Surface pro 5 1796
                              SN: 008793174853
                              CC
                              Become a Badcaps supporter
                              Thanks to all supporters.
                                Hi. Could you pleas help. Surface shows logo for few seconds and goes black.
                                Model 1796
                                Mobo M1007506-5015
                                SN: 023873573753
                                • kesko
                                  kesko commented
                                  Editing a comment
                                  Hello, my surface is shorted in the area of the 3.3 V area. I have to search. The bios didn't help me.
                                Model 1796
                                Mobo M1007506-5015
                                SN: 023873573753
                                Send to you, try
                                  Send to you, try
                                  Thanks, same problem after I programmed chip with Clear file, logo for 3 seconds and shuts down. Did you find any problem with original bios file ? If no major problem was in orignal bios it may indicate thi is HW problem :/
                                    Pleas if you can check another bios dump if there is trace of failed updated or anything that can prevent surface from booting? Thanks so much.
                                    Surface pro 5
                                    Model 1796
                                    Mobo M1007506-015
                                    SN: 054826391553
                                      sn/ 012308791653
                                      • Vesko356
                                        Vesko356 commented
                                        Editing a comment
                                        Thread merged.
                                        Before making a new thread please read the rules first, so I don't have to move your request at the existing thread again:
                                        You MUST
                                        • Post under a related thread if it exists
