ECS laptop ed20pa2 bios password
    Re: ECS laptop ed20pa2 bios password
    Just cycle the power until you get a code with the characters that you already have.
    Yes, the 1 at the end is always there, is the character that corresponds to NUL as the end of the string.
    CODE\0
      thx for your answer...
      but i have only 5 Laptops there is always a setup notice with 2 Characters that i didn't have.
      Can you tell me this codes, please?
      The Laptops are powered on...
      Thx regards,
      Stephan
        Setup Notice
        [Q3KPV8VB]
        password = WSOE0J0K1
        Setup Notice
        [94WZI1CM]
        password = LD99UAJU1
        Setup Notice
        [A82FU4G4]
        password = LJOU8DFD1
        Setup Notice
        [JZA7CE0G]
        password = Y9LUJIFF1
        Setup Notice
        [L5GHCUSB]
        password = IIFIJ89K1
          thx so much...
          but this password didn't work
          [QUOTE=AAAC;1276717]Setup Notice
          Setup Notice
          [JZA7CE0G]
          i think it is the J
          greatings, Stephan
            Just reboot and obtain a different code that does not include the "J" character.
            EDIT: It's probably your keyboard layout, as all passwords are calculated for a US QWERTY keyboard and the computer you are trying to unlock may have a QWERTZ German keyboard, I believe that's the reason.
              Hi AAAC,
              i have reboot and reset the passwords...
              and the QWERTZ Keyboard by me is the Reason for the "incorrect" J Character... it's not a Y, it's a Z by me ;-)
              Thx so much for your help and work...
                hello guys i have this LF78TRHV tyvm
                HI,goodmorning i have this code : W6SHBD1M ossible password? thank you
                  Good morning,I help you if you want,if anyone still have problems with the access codes for BIOS ,write here the code that appears to him so that I can send the unlock code,good day to all
                  Hi do you have another Code?
                    Hello i have this bios code X60YRJXV
                      hello can you send me another code because I have a problem only with the letter R that I am missing,just turn me a code without the letter R ,ok
                        YES, AGJZL2T8
                          AGJZL2T8
                            Setup Notice
                            [AGJZL2T8]
                            password = LFY9IOFJ1
                            L - LIMA ( UPPERCASE )
                            F - FOXTROT ( UPPERCASE )
                            Y - YANKEE ( UPPERCASE )
                            9 - 9 ( digit )
                            I - INDIA ( UPPERCASE )
                            O - OSCAR ( UPPERCASE )
                            J - JULIETT ( UPPERCASE )
                            1 - 1 ( digit )
                              Originally posted by AAAC View Post
                              Setup Notice
                              [AGJZL2T8]
                              9 - 9 ( digit )
                              1 - 1 ( digit )
                              Muchas gracias!!!!!! Thanks
                                Wanted to say thanks for the passwords, really helped me just now to get rid of an accidentally set password in an EJ20GM school notebook.
                                I made a small script in Lua for this, in case I end needing it in the future, and wanted to share it as well to any interested:
                                Code:
                                local map = {
                                  ["A"] = "L", ["B"] = "K", ["C"] = "J", ["D"] = "A", ["E"] = "I", ["F"] = "U",
                                  ["G"] = "F", ["H"] = "I", ["I"] = "U", ["J"] = "Y", ["K"] = "O", ["L"] = "I",
                                  ["M"] = "U", ["N"] = "N", ["O"] = "A", ["P"] = "E", ["Q"] = "W", ["R"] = "0",
                                  ["S"] = "9", ["T"] = "J", ["U"] = "8", ["V"] = "0", ["W"] = "9", ["X"] = "8",
                                  ["Y"] = "0", ["Z"] = "9", ["0"] = "F", ["1"] = "A", ["2"] = "O", ["3"] = "S",
                                  ["4"] = "D", ["5"] = "I", ["6"] = "F", ["7"] = "U", ["8"] = "J", ["9"] = "L"
                                while true do
                                  io.stdout:write("Challenge: ")
                                  local challenge = io.read("*l")
                                  if not challenge or challenge == "" then
                                    io.stdout:write("\n")
                                    break
                                  end
                                  challenge = string.upper( challenge )
                                  local password = {}
                                  for i = 1, #challenge do
                                    local c = string.sub( challenge, i, i)
                                    local d = map[ c ]
                                    if d ~= nil then
                                      table.insert( password, d)
                                    else
                                      io.stderr:write("\nInvalid character entered: " .. c .. "\n")
                                      os.exit(0)
                                    end
                                  end
                                  io.stdout:write("Password:  " .. table.concat(password) .. '1')
                                  io.stdout:write("\n\n")
                                  io.flush()
                                end
                                os.exit(0)
                                  Please help calculate for my one
                                  setup notice : 9JR0GOZ3
                                    Codice รจ: L30FFA9S1
