DELL Inspiron 15-5575 CAL51 LA-F121P Unlock BIOS
    Re: DELL Inspiron 15-5575 CAL51 LA-F121P Unlock BIOS
    Btw I appreciate it immensely to anyone who can help me out. I've searched for a couple days when I have time but everyone is charging to give out the passwords. And in having no luck whatsoever with any of the generators idk if I'm using os for 0s or ls for 1s or what but it's not doing anything productive for me. Su yeah worked be super stoked I need this laptop to work so i have something for school. Thanks again.
      @Sickboy311
      Please READ the instructions, start with NEW, give it 3 tries and then use OLD instructions if it does not work.
      NEW Instructions:
      - Reboot or power-on computer.
      - Enter calculated password, press and hold left CTRL key down, press ENTER key twice (CTRL-ENTER-ENTER).
      IMPORTANT: Give it at least 3 tries before continuing with OLD instructions, as some newer models require this alternate procedure to properly clear the system passwords.
      OLD Instructions:
      - Enter calculated password and press ENTER key.
      master.password = 66368207
      Dell, System Disable: [CE05D3261050C090]
      Inspiron 5575, 3X17LR2
        I get a new box that says:
        harddisk security
        SATA PORT 0 ST1000LM035-1RK177. LOCK (HIGHLIGHTED)
          @Sickboy311
          Type any password 3 times, to see if you get a new System Disabled code.
            I did in at work right now but when I get home I'll send it
              System Disable [DB4CAA026BBA2AF5]
              Service Tag [3X17LR2]
              hts failad 3 times
                Try each of the passwords 2-3 times using NEW INSTRUCTIONS, then proceed with OLD instructions if password still remain.
                NEW Instructions:
                IMPORTANT: Give it at least 3 tries before continuing with old instructions, as some newer models require this alternate procedure to properly clear the system passwords.
                OLD Instructions:
                master password = 29936009
                master.password = 98272704
                Dell, System Disable: [DB4CAA026BBA2AF5]
                  You my friend are a life saver I appreciate you more than you could imagine....
                    Can you do this with a latitude 5520?
                      Off topic. The latitude 5520 password thread is here -> https://www.badcaps.net/forum/showthread.php?t=103534
                        Originally posted by onizzbox View Post
                        Password : 98231710
                        In laptop: Type the unlock password and press <Enter>.
                        please generate a password for me
                        dell 16 digit hex bios password
                        3E1FEE8D57633DCA
                        Service Tag: C6C11X1
                        thank you in advance
                          3E1FEE8D57633DCA
                          Password:51642496
                            Originally posted by imranromi View Post
                            Password:51642496
                            THANK YOU CHIEF YOU'RE THE BEST
                              System Disable F08FB43D6A8789A2
                              Service tag JTLRBV2
                              dell 5575 unlock password please
                                Originally posted by vignesharivuslm View Post
                                system disable f08fb43d6a8789a2
                                service tag jtlrbv2
                                82305612
                                  Hi! It's a real pleasure to discover this post! So many times I try to find the solution to this lock on my computer. I don't understand why the BIOS is locked because I made Bios updates before but after this release, no more possible.
                                  System Disable: 33D3DABC0974B8DE
                                  Service tag: JSBJXQ2
                                  regards!
                                    dell 5575 unlock password please!
                                      PLZ HELP BIOS PASSWORD UNLOCK NEED MASTER PASSWORD URGENT
                                      DELL CAL51 LA-F121P
                                      SYSTEM DISABLE :- D0F9E9D4B222F203
                                      SERVICE TAG:- CX5TDP2
                                        EF00D0C74BD81403
                                        Service Tag: CX5TDP2
                                          Hi! Need help for unlock me password bios for me :
                                          Dell Insiron 15 model : 33308
                                          EXPRESS SERVICE CODE : 18477000758
                                          SERVICE TAG(S/N): 8HKQ912
                                          Thx very much !
