HP 640 G1 6050a2566302-mb-a04 WITH KEYBOAD PROBLEM
    HELP ME TREAT THIS BIOS FILE HP 640 G1 6050a2566302-mb-a04 WITH KEYBOAD PROBLEM
    Re: HP 640 G1 6050a2566302-mb-a04 WITH KEYBOAD PROBLEM
    try..
      is still the same thing no changes
        check keyboard, I/O chip
          There is a laptop with the same problem, before entering the BIOS and in the BIOS itself, the keyboard and touchpad work, immediately after exiting the BIOS they stop working, the laptop came with an embedded BIOS, there is a strong suspicion that the problem is in the BIOS, possibly in DMI or some kind of protective chip , tried different dumps - it doesn't help
            post the backup of the bios as it is, the name and the complete model of the laptop, the model of the motherboard.
              Все как у автора темы, HP 640 G1 6050a2566302
                And yet, tell me where to get a photo of the board in good quality, there are traces of soldering on one resistor, I want to make sure that it is in its place
                  try..
                    No changes, laptop works as well + asks for DMI data. I have doubts that the dump is native, although the serial number from the dump matches the number on the case, but there are traces of soldering on the BIOS chip.
                      try this too..it has a functional bios at its origin ..
                      what is the termination of the motherboard "mb-a04" or 'mb-a03 "???
                        Everything also does not work, for me mb-a02. Can you help with the photo of the board? near the hub and RTC battery
                          try..
                            Nothing has changed, most likely the problem is still in the hardware, thanks for helping
                              Replacing the hub and removing the TPM chip helped, removing the TPM separately did not help
                                bios extracted from dead motherboard
                                  goooddddd okkkkk thanks
                                    thanks master
                                      tnx
                                        This is HP ProBook 640 G1
                                        Part No : 6050A2566302-MB-A04
                                        PCID : A3009DD10303
                                        SERIAL NO : 5CG6164WMB
                                        problam No Display and High Speed fan Spining.
                                        attached Dump file
                                        plz share good working file plz
