Need bios hp fpw50 la-h323p rev: 1.0
    Originally posted by madjid911 View Post
    thanks for your help, it doesn't work, I think it must be a hardware problem, I have 5 long flashes and 3 short flashes on the shift key
    faulty mosfet PQA1
      Originally posted by SAX1975 View Post
      Ciao ho urgente bisogno del bios FPW50 LA-H323P REV.1.0 2019-01-04 notebook 15-dw0008nl il chip originale si รจ bruciato, ho acquistato un nuovo chip e ho caricato i vari file trovati in giro per il forum ma non funzionano, grazie per le risposte
      SN CND9233KY5
      SN CND9233KY5
      I attach a photo of the bios before the failure of the bios chip
        SN CND9233KY5
        The serial number posted does not match the one in the picture. The one in the picture is for laptop model 15s-du0058tx .
        S/N CND9233KY5 is model 15-dw0008nl . Is S/N CND9233KY5 on the base cover
          Originally posted by SMDFlea View Post
          Il numero di serie pubblicato non corrisponde a quello nell'immagine. Quello nell'immagine รจ per il modello di laptop 15s-du0058tx.
          Il numero di serie CND9233KY5 รจ il modello 15-dw0008nl . Il numero di serie CND9233KY5 รจ sulla cover della base
          sรฌ, confermo Il numero di serie CND9233KY5 รจ sulla cover della base, non so perchรฉ il numero di serie nella schermata del BIOS sia diverso.
          I would be so grateful if you could help me
            SMDFlea commented
            Editing a comment
            Post in english please !
          #85
          yes, I confirm The serial number CND9233KY5 is on the base cover, I don't know why the serial number in the BIOS screen is different, but it doesn't matter.
            Is there any hope of finding the right .bin file for pc 15-dw0008nl serial number CND9233KY5 ?
              hello, is there any chance you have a working bin file for FPW50 LA-H323p rev 2.0?
              hp 15s-du1063tx
              s/n: CNDO12581W
              ProdID: 9MT38PA#UUF
              here's my dump file in case you need it. thank you ..
                Hi, need clean Me this bios, Thanks
                FPW50 LA-H323P REV 1.0
                SN:CND1453DGH
                OLD BIOS
                I try all post above not work. BID- 085F, when i turn on i saw abit flashing on screen to black but no display.
                  HP Laptop 15-dw1113ne (58X72EA)
                  Win Key+Dmi @ 3A0000-3A103F
                    Thank you, I will try it.
                      CAPS flashing 3 times short 2 long
                        bios was extracted from HP support
                        3X2 HP Website indicates this could be memory related issue
                          Thank you, it was change but still same problem. any way I will check.
                            Your CPU is an i5-8265U ,it`s a Whisky Lake CPU. The PCH is Cannon Lake-LP. You want bios BID085EF
                            Try the attached bios.
                            If it doesn`t work try some older bios versions, download them from HP support.To extract run the exe and at the option screen select copy to location.
                            [Guide] How to find the right HP bios version to flash https://www.badcaps.net/forum/troubl...flash?t=122195
                            [Guide] How to extract ready for programming dump from HP update executable file https://www.badcaps.net/forum/showthread.php?t=121948
                              If it works the DMI can be edited with your serial number etc, or leave it as it is. If it doesn`t work try some older bios versions, download them from HP support.To extract run the exe and at the option screen select copy to location.
                              thanks so much
                                Should the EC.BIN file be folded after folding the 085EF file?
                                  SMDFlea commented
                                  Editing a comment
                                  If you have an EC programmer flash that as well.
                                #97
                                Click image for larger version  Name:	dataurl574456.png Views:	5 Size:	365 Bytes ID:	3542147
                                The notebook has now started, I can access the BIOS, going forward it shows me a screen that says Manufacture Programming Mode is in Unlock Mode and then it gets stuck on a screen with the HP logo.
                                It also says "preparing automatic recovery" with the HP logo in the center but it is stuck on this screen
                                Click image for larger version  Name:	dataurl272818.png Views:	0 Size:	365 Bytes ID:	3542189
                                  Click image for larger version  Name:	dataurl644484.png Views:	0 Size:	365 Bytes ID:	3542192
                                  I also tried to insert a pen drive with the Windows 10 operating system, changing the boot on the bios, but I cannot access the pen drive, neither in this one nor in other created ones.
                                    Try some older 085EF bios versions https://www.badcaps.net/forum/troubl...37#post3541737 .If you get one to work ok then you should be able to enter the DMI info and lock MPM with HP Bios Config Utility BCU.
                                      I still haven't been able to find the right bios......I have the original .bin file even if it is corrupted I attach it in the hope that it can be modified to make the notebook start, thank you very much
