i have a bricked laptop. I know it is the bios. I flashed a version that was posted in the beginning of this thread and the machine started up again.
I have made a backup beforehand and added this as an attachment.
If possible could someone provide me a bios with the my DMI information copied to a new BIOS.
If needed i can provide the cap file.
I would also be happy with the correct offsets so i can try it myself.
machine information :
idea pad flex 5 14are05
model name 81x2
serial r90xzmv3
model name 81x2
serial r90xzmv3
"take a look at this"
Add a description of the problem!
---------------------------------------------------------------------------------------------------------------------------------------------------------- All donations to Badcaps are welcome. Become a Badcaps supporter >>>>>click on this link to donate <<<<< Thanks to all supporters.​ ----------------------------------------------------------------------------------------------------------------------------------------------------------
Can someone help me fix the attached bios file?
No image and no post after bios update..
LENOVO IDEAPAD FLEX 5 14ARE05 (81X2)
Motherboard model in attachment too.
Hi Everyone,
I have the Flex 5 -14ARE05, Esc and Caps Lock lights are on, black screen, fans kick in when required and the laptop charges.. From what I have read on here these seem to be the same symptoms that others on here are getting therefore re flashing their bios to cure the problem.
I have tried flashing my bios and a number of bios's from this thread only to end up with exactly the same symptoms, nothing changes no matter which bios I flash. I am using the CH431A V1.7 which allows me to select 1.8v without an adapter. This I have also confirmed with a multimeter. My bios chip is a MX25U12873F and my logic board is a LC55-14A.
Can anybody help me with this issue?
Many thanks
Hi Everyone,
Many thanks
If you want further help beyond a bios request start a new thread here:
you have the bios at post #3 ..
DMI B21000 - B213FF
Hi Peste,
used the bios in post 3 however same result. Can the DMI information, windows key and serial number be transferred to the new bios if possible. thanks again
if it doesn't work, either you wrote the bios with errors or the laptop has another problem.. use the HxD program to transfer the DMI information from one bios to another.. enter both bios into the program and then (copy-paste) from one bios to the other.. the interval ( DMI) which must be copied, you can find it at item #51..
Hi, can anybody repair my not working bios?
Model : 81X2
Serial : R911K97P
many thanks fluepp
Bios file you need at #45
Hello seniors, please help, the Lenovo laptop has no screen display after updating Windows, when I wanted to retrieve the bios file I found damage to the bios IC, I tried flashing the bios From the files in this forum, it displays successfully, but after I turn off the laptop and turn it on, there is no display anymore.
Please repair this file
LENOVO IDEAPAD FLEX5 14ARE05
Kode board LC55-14A 19793-1M
448.OK103.001M
SN R90ZR6WK
TYPE 81X200EGID
448.OK103.001M
SN R90ZR6WK
TYPE 81X200EGID
Hi everyone
Can someone help me fix bios
No image and no post after bios update TO FXCN48WW.CAP
LENOVO IDEAPAD FLEX 5 15itl05 sn: R9119MNX
LC56 - 14T
203044 - 1
THANKS
Hi everyone
LC56 - 14T
203044 - 1
THANKS
post the original bios of the laptop even if it is corrupted,
