IdeaPad 3 14ADA5/15ADA05/17ADA05 Lenovo V14-ADA/V15-ADA Bios
    Originally posted by Robyprosd View Post
    Good morning!
    My lenovo V15 ADA 82C7
    SN PC1V2F52 has black screen and fan at maximum, this is the dump, can you help me?
    Thank you
    you have everything you need at post #1 and 12...
      good morning I'm new
      v15-ada model
      gv451&gb551 nm-d151
      s/n PF30FQXZ
      The notebook turns on but the screen remains black
      I extracted the original bios
      can someone help me? A thousand thanks
        SMDFlea commented
        Editing a comment
        post your bios backup inside a rar or zip attachment
      this is the original BIOS. Thank you
        before asking you, I tried to put the various bios that I found in the forum. but nothing to do. Thank you
          read post #201..
            I read all the post before asking and I'm stuck. Thanks anyway, I tried it anyway.
              Bios extracted from Lenovo website update for IdeaPad 3 14ADA05, IdeaPad 3 15ADA05, IdeaPad 3 17ADA05, V14-ADA, V15-ADA
              DMI 1000 - 2FFF
                the bios you posted has 4MB...it should have 8MB, so you write and read it with errors...and because of this it doesn't work...remove the bios chip from the motherboard before writing or reading. ..if you don't have anything to stick wires between the chip and the programmer..don't use clipsil because it gives errors..
                  Originally posted by AlexanderToro View Post
                  Re: IdeaPad 3 14ADA5/15ADA05/17ADA05 Lenovo V14-ADA/V15-ADA Bios
                  z,x,c,v,n,m,enter keys don't work, keyboard is ok. does anyone know how to fix it. I have looked for the EC Bios but I can't find it.
                  tested file ok
                    Hi
                    My screen went black and I downloaded a bios from this topic. It is working perfectly. >) . However, I do not know now the original serial number and other data as the label from the bottom of the laptop is gone. I hope someone can help me to extract the data from the dead bios and inject it into the working one. I attached both. thx
                      SMDFlea commented
                      Editing a comment
                      Post 1 has everything you need to add the DMI yourself.
                    Originally posted by bociub View Post
                    Hi
                    view
                      Hi, I have a Lenovo V15-ADA laptop that will turn on but nothing else. I have checked around the board all seems ok, so I wanted to try a new bios. If possible could someone have a look at this for me, I have attached a zip file with the original bios and the laptop serial number. Any help would be appreciated. Thanks
                        SMDFlea commented
                        Editing a comment
                        Everything you need is in this thread,start by reading post 1 .Also the serial number must be typed and posted, please read and familiarise yourself with the rules
                        You MUST:
                        • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                      Hi, apologies for that. Ill read through the posts. The board is a GV451&GV551 NM-D151 Rev:1.0 S/N PF257F49
                        I have a black screen, power button blinking with my Lenovo 17ADA05.
                        I have tried to flash a new bios with DMI data but I have the same problem.
                        Can you provide to me a corrected bios ?
                        SN: PF2K9A2R
                        MTM : 81W20059FR
                        Factory ID : JVHFC1
                        MP : PF9XB1116193
                        Thank you !
                          SN: PF2K9A2R
                          MTM : 81W20059FR
                          Factory ID : JVHFC1
                          MP : PF9XB1116193
                          Thank you !
                          check the virgin bios extracted from lenovo support first if you get image than further dmi will see later
                            Thanks for your reply.
                            I have flashed that bios but I have the same problem..
                            EDIT : I have only black screen, power button light on. I have tried with novo button but that is the same problem
                              Can you provide to me a corrected bios?
                              SN: PF1SY66P
                              MTM : 82C7S02600
                              Factory ID : JVHFC1
                              MP : PF9XB0909191
                                SN: PF1SY66P
                                MTM : 82C7S02600
                                Factory ID : JVHFC1
                                MP : PF9XB0909191
                                If you have made a good backup using an SPI programmer then you have everything you need in this thread.
                                https://www.badcaps.net/forum/troubl...51#post1808151
                                https://www.badcaps.net/forum/troubl...post3237606
                                If you`re unsure if your backup is good or not post it and someone will help.
                                  Good morning everyone, I have a problem with my Lenovo, it turns on but the screen remains black and caps lock doesn't work. I tried some loaded bios and also the procedure described in the first post. Could someone help me figure out if I'm doing something wrong? Thanks a lot to everyone
                                  Ideapad V15 ADA
                                  model: 82C7
                                  SN: PC20RVW8
                                  MTM: 82C7007SIX
                                  Motherboard : GV451&GV551 NM-D151
                                    Ideapad V15 ADA
                                    model: 82C7
                                    SN: PC20RVW8
                                    MTM: 82C7007SIX
                                    Laptop V15-ADA (Lenovo) - Loại 82C7
                                    Become a Badcaps supporter
                                    Thanks to all supporters.
