IdeaPad 3 14ADA5/15ADA05/17ADA05 Lenovo V14-ADA/V15-ADA Bios
    Originally posted by hoaca388 View Post
    Laptop V15-ADA (Lenovo) - Loại 82C7
    Thanks, but unfortunately it doesn't work
      Check hardware, this is an origin bios.
      Become a Badcaps supporter
      Thanks to all supporters.
        hello
        I have problem my old bios no display, i flashing with other bios display but always beep every second time.
        can rebuild my old bios attached.
        Lenovo Ideapad 3 14ADA05 81W0
        Board GS540/GS550/GS750 NM-C821 Rev 1.0
        SN : PF3FEG4N
          Originally posted by notrespond View Post
          hello
          SN : PF3FEG4N
          IdeaPad 3-14ADA05 Laptop - Type 81W0
            Originally posted by Atiq View Post
            Re: Lenovo V15-ADA NM-D151 Rev 1.0
            Thank you it's working 100%
            thank you %100 Work
              Hello.
              Can you help me with this bios? Black screen problem.
              Ideapad 3 17ADA05 , Model 81W2
              SN: PF2LJHRH
              MTM: 81W20074RM
              Thank you.
                SMDFlea commented
                Editing a comment
                Post moved. See post 1 you can try to fix it yourself.
              try
              Thank you very much, the laptop works correctly.
                Hola me podrían ayudar mi computador Lenovo Ideapad 315ada05 quedo en pantalla negra, queda encendado el disco duro, se enciende el fan cooler por el calor del cpu y el botón de encendido queda parpadeando. He investigado y veo que es la Bios corrupta.
                Si alguien me podría ayudar, lo agradecería mucho. Dejó aquí los datos del Notebook
                Ideapad 3 15ada05
                N/S: PF2BWHQ3
                MODELO: 81W1
                MTM: 81E11008CL
                Hello, could you help me? My Lenovo Ideapad 315ada05 computer has a black screen, the hard drive remains on, the fan cooler turns on due to the heat of the CPU and the power button keeps flashing. I have investigated and I see that the BIOS is corrupt.
                If someone could help me, I would really appreciate it. I left the Notebook data here
                  Ideapad 3 15ada05
                  N/S: PF2BWHQ3
                  MODELO: 81W1
                  MTM: 81E11008CL
                  English ,please.
                    Ideapad 3 15ada05
                    N/S: PF2BWHQ3
                    MODELO: 81W1
                    MTM: 81E11008CL
                    you have everything you need at #217.post..
                      please help me model V15-ADA no display after bios upadate
                      S/N PF283EBN
                      MTM 82C7005RPH
                      FACTORY ID JVHFC1
                        S/N PF283EBN
                        MTM 82C7005RPH
                        FACTORY ID JVHFC1
                        post the original bios of the laptop even if it is corrupted.
                          S/N PF283EBN
                          MTM 82C7005RPH
                          FACTORY ID JVHFC1
                            THANKS
                              THANKS
                              you have everything you need at post 217
                                S/N PF283EBN
                                MTM 82C7005RPH
                                FACTORY ID JVHFC1
                                heres my backup bin
                                  S/N PF283EBN
                                  MTM 82C7005RPH
                                  FACTORY ID JVHFC1
                                  heres my backup bin
                                  V15-ADA Laptop (Lenovo) - Type 82C7
                                    thank you so much
                                    doesnt work still no display
                                      thank you so much
                                      Check hardware
                                        Hello ,
                                        i have tried methods from post #1 but obviously i cant fix it by myself. i will appreciate if someone can fix it for me. Symptoms are black screen after bios update....TNX
                                        Lenovo V14-ADA
                                        MODEL NAME: 82C6
                                        SN: PF23EAJW
                                        MTM: 82C600ERM
