Dell 7300 locked bios
  • Blaze Tech
    Learner
    • 205
    • Ghana
    #81
    Originally posted by Khaled Mohamed
    Hi i need to unlock bios for Dell latitude 7300 if is posible i need clear bios bicose i have master password thnx
    Service Tag :17FY633
    Model Board :EDC30 LA-G861P REV:1.
    TRY
    • lint4u
      • Nov 2013
      • 114
      • lint4u
      #82
      Pls help to unlock Dell 7300 8FC8
      Service Tag : HMXS1Z2
      Tq.
      • rex98
        • Feb 2023
        • 1278
        • Mandaue CEBU, Philippines
        #83
        Tq.
        1st boot, press F2, write service tag, disable Absolute, save (Apply changes), restart. 2nd boot press Alt+F to exit manufacturing mode
        • lint4u
          • Nov 2013
          • 114
          • lint4u
          #84
          Thank you Sir
          It's working
          • don166
            • 35
            Help please unlocking Dell Latitude 7300 BIOS (ST 5T15H53, MOBO LA-G871P) with 8FC8 lock. Dump attached. Thank you.
            • sancheti81
              • May 2014
              • 191
              • India
              #86
              try
              • don166
                • 35
                Worked - thank you.
                • sebastiannielsen
                  • May 2024
                  • Sweden
                  #88
                  Dell Latitude 7300.
                  Tried to unlock bios using the 8fc8 patch, but didn't work. Reprogramming the original bios doesn't work either.
                  using CH341a with NeoProgrammer 2.2.0.10 which identified the bios chip as 25Q256 but quess 25B256 and 25Q256 is the same thing when it comes to programming.
                  Reading BIOS was done by read + successfull verify, so the content should be exactly whats on-chip.
                  The computer immediately turns on when attaching DC power. Then it just loops with black screen, turns itself off, and then on again after like 30 seconds, and does the same again.
                  Also tried crisis recovery with the original BIOS inside chip without luck.
                  Service tag: 6YYHN73 - Express: 15174474159
                  BOARD ID:
                  COPYRIGHT 2019
                  ALL RIGHT RESERVED
                  REV:A00
                  PWB P/N:M8XW5
                  jdimm2
                  BIOS CHIP (UC5):
                  GigaDevice
                  AJ2017
                  25B256DYIG
                  UAF186
                  Original bin and patched bin attached to thread. (the LRT_Unlock is the patched one, the LOCKED_DELL.bin is the locked one)
                  • Markus1741
                    • Sep 2020
                    • 843
                    • N/A
                    #89
                    My assessment of your notebook I think your original file is fine.
                    I guess your patch was made using the method search in HxD Editor for 010000 and then from offset 0045000 with a long of 4000 to fill everything with FF.
                    That's not something we like to see here. It doesn't have to work.
                    Here everyone will only exchange four bytes for you and the notebook will start after several starts in manufacturing mode (patience is the magic word) and the CMOS will also be disconnected.
                    Just try this new patch.
                    Please also be patient, the start up to the Dell logo can take some time.​
                    • sebastiannielsen
                      • May 2024
                      • Sweden
                      #90
                      Now to the results.
                      flashed in the file and verified the flash went good. worked perfectly, went into FACTORY MODE.
                      but now to the odd thing:
                      While in factory mode, and entering the service tag, the computer dies randomly before I got to save the service tag, it just rebooted in the middle of entering it.
                      Tried again, went into factory mode, started entering service tag but it then died randomly again. (both times on DC power).
                      Now it just turns on, fans on full speed, caps lock LED on.
                      no beeps.
                      Display test (D key) works.
                      Tried reflashing the file again (I could see that the file does not match anymore, so the computer writes something to the BIOS).
                      Same result.
                      Verifying the BIOS chip shows that the content is again changed, so apparently it can boot the bootloader for the BIOS chip.
                      I guess there is some hardware fault on the computer, so any ideas what it could be?
                      Here is how the computer behaves:
                      On DC only: Computer reboots every like 30 seconds, fans full speed, caps lock LED on, screen black.
                      On battery only: Computer is stable, but screen is black all the time. Have had it on for like 15 minutes.
                      On DC + Battery - same as Battery only.
                      Tried both with BIOS battery attached and detached.
                      Any ideas what could be the problem?
                      • reamon
                        • Aug 2020
                        • 24
                        • United Kingdom
                        #91
                        Hi, My laptop has bios password. BXSGL33-8FC8
                        Dell Latitude 7300
                        S/T: BXSGL33
                        Here is bios dump. Please unlock it.
                        Thanks,
                        Attach
                        • Blaze Tech
                          Learner
                          • 205
                          • Ghana
                          #92
                          Dell Latitude 7300
                          S/T: BXSGL33
                          Thanks,
                          Attach
                          try
                          • reamon
                            • Aug 2020
                            • 24
                            • United Kingdom
                            #93
                            Originally posted by Blaze Tech
                            try
                            Worked - thank you
                            • don166
                              • 35
                              Need help unlocking two Dell 7300 laptops with 8FC8 locks. STs J30YP13 and CJ9NQ13; MOBOs LA-G861P. Dumps attached. Thank you.
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11733
                                #95
                                Unlocked
                                • don166
                                  • 35
                                  Thank you once again for the help.
                                  • vuquanghoanh
                                    • Feb 2023
                                    • 45
                                    • US
                                    #97
                                    Could you help me to unlock the admin password, please?
                                    Model : Dell Latitude 7300
                                    Motherboard : EDC30 LA-G861P Rev: 1.0 (A00)
                                    S/T: B73QF13
                                    Thank you.​
                                    • minhdigital
                                      • Nov 2022
                                      • 751
                                      • Vietnam
                                      #98
                                      S/T: B73QF13
                                      Thank you.​
                                      Send to you
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 11733
                                        #99
                                        S/T: B73QF13
                                        Thank you.​
                                        AAA
                                        • vuquanghoanh
                                          • Feb 2023
                                          • 45
                                          • US
                                          #100
                                          Originally posted by hoaca388
                                          AAA
                                          Working well. Thank you so much
                                          Hoạt động tốt anh ạ.
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • dr_crx
                                            Dell 7740 Bios locked J3JSD43-8FC8
                                            by dr_crx
                                            Hello i need help please
                                            i have DELL 7740 ST: J3JSD43-8FC8
                                            i tried to read bios bit i think it is wrong because the size of the file is around 1mb
                                            anyone can help to show its location on motherboard please.
                                            i attached the results file the IC i read is : winbond 25q80dvsig
                                            i don't know if its the needed bios or another bios on the motherboard.
                                            thank you in advanced for your help...
                                            07-11-2025, 12:22 AM
                                          • jhanra
                                            by jhanra
                                            in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                            11-02-2024, 04:19 AM
                                          • gizaha
                                            by gizaha
                                            02-13-2024, 07:18 AM
                                          • bmxlovah
                                            Dell Precision T7910 no bios, no post after applying SAS/RAID setup
                                            by bmxlovah
                                            My Dell Precision T7910 died after enabling onboard SAS controller and applying RAID settings. There were no hardware changes between working and not working state, only setup (via bios -> controller settings). After applying settings and reboot PC turns on, flash leds (normally) but there's no further action, it just stays on with no graphics and no keyboard led's on. There's no Dell logo, nothing. I've tried resetting bios by jumper, replacing cpu's, replacing ram, removed/replaced cmos battery, disconnecting all drives etc. I've also dumped .bins from mobo chips SLI1 (16...
                                            11-24-2022, 06:29 AM
