B15 LAPTOP CORE i5 5257u BIOS NEEDED
    Hi guys. i have a laptop bin that needs to be repaired. After a bios update the machine didn't power on just blinks caps once. Again the laptop has no name on it completely. But online it is a B15 i5 5257u and the board number is BUB_M01 VER:1.1 Attached is the Original BIN. Kindly someone fix it for me i will be glad.
    Re: B15 LAPTOP CORE i5 5257u BIOS NEEDED
    Did the bios update come from windows update or a built in updater.Post pictures of stickers on the bottom case and motherboard part number
      it was a windows update bro. The bottom case has no details completely. Trust me there's no any form of any information on the entire casing. let me take a pic of the board number section
        Attached are the board images
          guys can you help me with the above problem kindly?
            try..
              i tried that bin still not working. 3v 5v present bios chip no voltage. switch has 3vlts. i still believe its bios. wen pressing power button caps lock flashes once and thats it
                On some boards the bios voltage comes up after pressing the power button.
                The bios has some info about the model , AIERXUAN XIAOXUAN Pro .
                  I still havent managed reviving that machine. I dont know what i wl do about he bios issue. The bios chip voltage is 3v. Thats when programming. I just need one last bin file to try if it works well if it doesnt i throw it away
                    What is the bios voltage when pressing the start button. If you contact aierxuan they might send you a bios if you`re very lucky http://www.aierxuan.com/portal.php?mod=view&aid=71 ,or wait until someone with the same laptop posts a dump.
                      Thanks SMDFlea. Al wait someone to post it. Though had to sell it in parts
