Lenovo Ideapad S145-15IWL BIOS
    Hi friends,
    I have a problem on Lenovo Ideapad S-145-15IWL NM-C121. Can't open windows 10. Freezing on windows installation. I to Upload bios version 38ww and it worked well but when i update it to 51ww version it freeze again, and it shows 0xc000000f error message. I try to install again it freeze while opening the installation screen. Can anyone help me.
    Re: Lenovo Ideapad S-145-15IIL BIOS
    Originally posted by raajkumar View Post
    Hi friends,
    Post your backup,and serial .
      Re: Lenovo Ideapad S-145-15IWL BIOS
      here my backup file i attached.
      LENOVO IDEAPAD S145-15IWL
      MODEL : 81MV
      S/N: PF1P88FR
      MTM: 81MV008AUS
      FACTORY ID: JVHFC1
        anyone can help me ?
          Bios extracted from lenovo update.
            Thanks for your help. I will try and get back to you.
              Sorry Bro. I upload the bios dump on that chip but not showing anything on screen. Its switched on and its off after 20seconds and on again but nothing on screen even screen not switched on and keyboard not responding ( CAP's lock key ) do you have any solution on it?
                lenovo IdeaPad S145-15IWL
                tested
                work good
                  Lenovo Ideapad s145-15IWL BIOS needed
                  Hi friends,
                  I need a BIOS for Lenovo Ideapad s145-15IWL, model name : 81MV.
                  If failed on my during a previos BIOS update.
                  MB name : F440/FS441/FS540 NM-C121
                  REV 1.0
                    Re: Lenovo Ideapad s145-15IWL BIOS needed
                    Originally posted by claudiunew View Post
                    Hi friends,
                    REV 1.0
                    Upload your original bios file and write you device serial number.
                    all donations are welcome,
                      lenovo IdeaPad S145 Flashing Power Button Led
                      i also have the same problem, the led indicator is blinking and no screen display. please someone to fix my old backup bios
                      here are the laptop details and the original bios is attached
                      lenovo ideapad s145-15IWL
                      Motherboard: FV440/FS441/FS540 NM-C121 Rev. 1.0
                      Serial Number:PF1Y210W
                      Model:81MV
                      THANKYOU
                        Re: lenovo IdeaPad S145 Flashing Power Button Led
                        Model:81MV
                        THANKYOU
                        Here's your New Bios, it's a Virgin Bios from Lenovo with your DMI.
                          Guys sorry to drag this string up again however we are struggling. We have a lenovo S-145-15IWL with a flashing power light. Usually, this is a bios corruption and we would order a programmed BIOS chip and solder on however to save time we have purchased a chip programmer in order to solve it straight away.
                          The model is S-145-15IWL
                          Serial number - PF1TW1D3
                          Model - 81MV
                          Motherboard FS540 10 F2
                          I have downloaded the EXE bios from Lenovo which includes an F2 file that is too large for the chip once extracted and have tried a couple from BC however still getting light flash on boot.
                          Could anyone please supply an appropriate bios which is compatible with the above model?
                          Thanks in advance!
                            Model - 81MV
                            Thanks in advance!
                            Did you make a backup of the bios before you tried any others. Post it here if you did.
                              Sorry no - Assume now dead?
                                If you have no Backup try this file, it could help you.
                                  i also have the same problem, the led indicator is on and no screen display.
                                  lenovo ideapad S145-15IWL
                                  Serial Number:PE05CA6W
                                  Model:81S9
                                  I'm attaching the bios backup, but i guess it is not correct
                                    hi Folks, this machine dot no powerup
                                    Model: S145-15IWL
                                    MO: PE9039C22034
                                    MTM:8159000DBR
                                    S/N:PE05C3W2
                                    mb: FV440/FS441/FS540 - NM-C121 Rv: 1.0 2018-12-12
                                      Model: S145-15IWL
                                      MO: PE9039C22034
                                      MTM:8159000DBR
                                      S/N:PE05C3W2
                                      try post#16
                                        Originally posted by peste View Post
                                        try post#16
                                        hi try post#16 and now not even the LED that indicates that it is charging works, some other suggestion I am open to listen and execute, thanks
