RCUnlocker
    Re: RCUnlocker
    I have HP Elitebook 850 G8, locked BIOS. Has anyone tried with this tool?
      Re: RCUnlocker
      This tool doesn't work with 32MB file but you can post your bios and EC file here.
      Become a Badcaps supporter
      Thanks to all supporters.
        Re: RCUnlocker
        super hp probook 450 g7 unlock
          Re: RCUnlocker
          450 G7 thread -> https://www.badcaps.net/forum/showthread.php?t=91780
            Re: RCUnlocker
            EC file?
            I will extract both bios chips if I find them
            Probably the one under keyboard is the one I need to flash, right?
            I will do it in few hours.
            edit:
            I found this youtube video: https://www.youtube.com/watch?v=OG_xNKi1QKU
            I think it might be working. Any comment on this?
              Re: RCUnlocker
              EC file?
              edit:
              Yes, it is.
                Re: RCUnlocker
                Hi, I have a problem with RCUnlocker. Checksum is still the same even after unlocking.
                  Re: RCUnlocker
                  Yes, it is.
                  I am not able to upload files.
                  I will send the link to it.
                  Can somebody help me with unlocking?
                  https://files.fm/u/kvbsfna3p
                    Re: RCUnlocker
                    I have tried flashing chip on back side with method from the video i linked 3 posts above. But it is still asking for bios admin password. Also when i turn on the laptop it is showing company logo, not HP, but company that used to own that LAPTOP. might that be the problem why flashing did nothing?
                    Any help is welcome.
                      Re: RCUnlocker
                      Hi, does ir works for HP SWAT LOCK?
                        Re: RCUnlocker
                        read post #1..
                          Re: RCUnlocker
                          HP EB 840 G8 BIOS locked. Is the chip needing reprogramming a Winbond 25Q256FV on the underside of the board and is it the only one needing such work?
                            Re: RCUnlocker
                            Post your bin file, I'll do the unlocking for you. If in doubt, post both bins, I'll figure which is which.
                              Re: RCUnlocker
                              Originally posted by AAAC View Post
                              @ogre4273
                              I've been modifying only the 32MB chip.
                              Dump and save the file 3 times, then check all 3 files are identical (if you use a utility like WinRAR or similar, you can ZIP or RAR the files, then open the ZIP or RAR resulting file, on the far right there's a column with CRC32 values, if all they match all the files are exact copies).
                              Man, I learned something good today, thank you, it will save a few minutes and lots of headaches if not done properly.
                                Re: RCUnlocker
                                Can you publish the source code?
                                  Re: RCUnlocker
                                  what problems do you have ..give me more details..which source code??
                                    Re: RCUnlocker
                                    Thanks, now all I have to do is figure out how to make those bin files. I`m an utter newbie to all of this, so please bear with me.
                                      Re: RCUnlocker
                                      In an attempt to learn more I downloaded the RCUnlocker rar file and using Zipware I extracted it as an .exe fil to a desktop folder. when I open the ,exe file in the bunch of files in the folder all I get is a white rectangle with three different colour one liners texts and nothing more happens at all. WTF? What am I doing wrong?
                                        Re: RCUnlocker
                                        Hey RethoricalCheese could you publish the source code for this tool?
                                          Re: RCUnlocker
                                          It doesn't open in my PC don't know why
