HP Elitebook 850 G6 BIOS UNLOCK
    Re: HP Elitebook 850 G6 BIOS UNLOCK
    Originally posted by bl5 View Post
    I've got a 850 G6 which needs the BIOS password removing, when I open the laptop I am able to see the 256 chip which is labelled winbond 25Q256JVEN. I have been looking at threads on the forum and some people are saying this is the correct chip to flash. Is this correct or is there another on the other side of the board? Any pictures would be really helpful.
    the password is in the 16 MB bios chip... see post #11 and 15..
      Thanks, I will open and look for the 16mb chip when I get some time this week.
        HELLO I HAVE HP ELITBOOK 850 g6 .
        Good morning
        I have a problem with hp elitbook 850 g6 after updating
          Originally posted by pokyss1 View Post
          hello i have hp elitbook 850 g6 .
          Good morning
          i have a problem with hp elitbook 850 g6 after updating
          aaaaaaaaa
          Become a Badcaps supporter
          Thanks to all supporters.
            thank you works great
              Hello!
              The HP 850 G6 laptop does not start after unlocking and rewriting. Unfortunately, the original BIOS is not available. I can upload transcribed content.
              Could you help me?
              Sorry:SN:5CG941023G
              MotherBoard:10/07 m/b sps:l62759-601
                Originally posted by szuts View Post
                Hello!
                Could you help me?
                Serial number?
                Read the rules before posting
                Thanks to all supporters.​
                  Please unlock my Elitebook 850 G6.Thenk You
                    Read post #27 !!!!!!! READ THE RULES !!!!!!!!!!!!!!!!!!!!!!!!
                      I read the rules. I replaced the serial number. Do I have anything else to do?
                        Pleace unlock my Hp 850 G6
                        SN 5CG9328964
                          SN 5CG9328964
                          read post#27...use RCUnlocker
                            SN 5CG9328964
                            here u go
                              Niestty does not work, after uploading such screens appear, the unlocker does not work
                                needs to unlock thanks in advance
                                HP elitebook 850 G6 BIOS UNLOCK
                                sn:5CG0102W1L
                                  sn:5CG0102W1L
                                  in first boot press f10 reset to defaults.
                                  use BCU or MPM tool.
                                  if you don't know how to fill those info in bios just upload the EC for Easy unlocking.
                                  Serial Number: 5CG0102W1L
                                  Product Number: 6XD57EA#ABU
                                  CT Number: PHWHB00WBDG1TL
                                  Description: HP EliteBook 850 G6
                                  build_id: 19WWCFBT601#SABU#DABU
                                  Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfAfPhKhkjhk8.BQ
                                  MAC Address: 38-22-E2-4B-7C-FA
                                    great works fine 😀thanks
                                      I need to unlock my bios password please
                                      HP EB 850 G6
                                      thanks
                                      • Vesko356
                                        Vesko356 commented
                                        Editing a comment
                                        You MUST:[LIST][*]Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.[/LIST
                                      #40
                                      I'm trying to repair HP Elitebook 850 G6 with damaged and unreadable EC 16MB chip. I've replaced it with exactly the same chip from donor motherboard and flashed it with couple firmwares. Laptop is waking up every time and it seems that it's working properly but I'm getting "HP Endpoint Security controller problem" at boot. I've tried couple EC firmwares from this forum but this problem persists and I cannot find any way to fix it.
                                      Is there any way to recreate EC bios from scratch or extract if from the main bios?
                                      Model: HP Elitebook 850 G6
                                      MB SPS: L62758-601
                                      System BIOS: R70 Ver. 01.26.00 10/02/2023
                                      ME Firmware Version: 12.0.93.2331
                                      ME Firmware Mode: Enable
                                      Audio Controller: Realtek ALC3294
                                      Video BIOS Version: Intel(R) GOP Driver [9.0.1085]
                                      Reference Code Revision: 7.0.77.0
                                      Embedded Controller Firmware Version: 52.6F.00
                                      USB Type-C Controller(s) Firmware Version: CCG5:2.5.0
                                      Born On Date: 02/26/2020
                                      Serial Number: 5CG9527NJM
                                      SKU Number: 4YD61AV
                                      Universally Unique Identifier (UUID): CAE3150163F5964A5A636D6EB5C74B5C
                                      UUID (standard format): 0115E3CA-F563-4A96-5A63-6D6EB5C74B5C
                                      uawbUbhcAdUdpdqfAfPfXhKhkjhk8.T7
                                      Build ID: 19WWCFBT601#SUUG#DUUG
                                      Product Family: 103C_5336AN HP EliteBook
                                      System Board ID: 8549
                                      System Board CT Number: PHWHBOOWBD6885
                                      Integrated MAC Address 1: E8-D8-D1-E9-58-04
                                      I'm attaching main bios dump.
