help need clean bios dell latitude 3420
    Re: help need clean bios dell latitude 3420
    pleas can anny one Help with Dell latitude 3420 (2021) bios winboond W25R256jv
    thankx
      thankx
      What's your issue : passwoed , computrace , no power or no display !
        sorry this is with Bios password
          thankx
          1st boot, press F2, write service tag, disable Absolute, save, restart. 2nd boot press Alt+F to exit manufacturing mode.
          All donations to badcaps are welcome, donate via PayPal. Every donation made will go towards server fees and maintenance costs.
            Hello I need to unlock my dell 3420
            9STG2L3-8FC8
            I don't have bios recorder, how could I do.
            Help me
              9STG2L3-8FC8
              Help me
              You need to dump yuor bios and post right here
                Re: help need clean bios dell latitude 3420 - try that bios tested
                Originally posted by alexm22 View Post
                Hi guys I need to delete the bios key from my dell latitude 3420 I attached original bios and my region would appreciate your help
                Please try it
                  Need help with Dell 3420 bios can't get the power
                  SVT: 79PMQG3
                    Hello. Could someone help me to remove the administrator password and deactivate the Absolute Persistent Module?
                    DELL 3420 213093-1
                    SERVICE TAG: FC76BG3
                      DELL 3420 213093-1
                      1 boot service tag, disable absolute , 2nd. boot alt f to exit mode
                      let me know if it worked for you
                        DELL 3420 213093-1
                        if mandrake's file doesn't work try this.
                        1st boot, press F2, write service tag, disable Absolute, save (Apply changes), restart. 2nd boot press Alt+F to exit manufacturing mode.
                          I tried the mandrake file and yours and in both it does not give me the option to disable Absolute, this option is disabled and it brings a note that says that when computrace is active these options will not be enabled.
                          Is there anything else that can be done?
                          The administrator password has been deleted. thank you so much
                            Tests and comments.. 1st boot, press F2, write service tag, disable Absolute, save (Apply changes), restart. 2nd boot press Alt+F to exit manufacturing mode.
                              hi can you help me to fix and clean this bios for dell latitude 3420
                              Service Tag: 2H6NR93
                              ISSUE: NO DISPLAY /BIOS PASSWORD
                                unlock my bios.password. sn2M6CHG3
                                  Try this file than replay
                                    Try this
                                      unit has now display
                                      but after setting up the bios and restart not turning on
                                        after this confirm changes
                                          hi update again unit is now ok
                                          thank you very much for your help
