Extract bios password from EliteBook 840 G8 Bios dump, possible?
    Originally posted by hoaca388 View Post
    Unlocked
    Thank you very much, it worked!
      Originally posted by Ghost18_07 View Post
      Same, can't access the BIOS menu, the password is still there.
      Well, it seems like i have an uncommon case here, i hope that someone can find a solution, thanks in advance for your help.
        Post EC file. 32BM other.
        Become a Badcaps supporter
        Thanks to all supporters.
          Here it is.
            Here it is.
            Unlocked
              Unlocked
              It worked just fine, thank you Hoaca.
                HELLO GOOD AFTERNOON FRIEND
                I HAVE HP 840 G8 WITH COMPOTRACE LOCK
                SN::::5CG14299DN
                HAVE TRIED MANY FILE BUT NOT POWERING
                PLS HELP ME
                  SN::::5CG14299DN
                  PLS HELP ME
                  Try
                    SN::::5CG14299DN
                    PLS HELP ME
                    Unlocked
                      I need this bios password unlocked.
                      Prod ID 19X35AV
                      S/N#5CG1247M00
                      CORVETTE-6050A3217501-MB-A01 (A1) (1086) L2
                      If you need anything else, do tell.
                      Thanks.
                        Prod ID 19X35AV
                        S/N#5CG1247M00
                        Thanks.
                        HP EliteBook 840 G8 Notebook PC
                        CT Number_6LGWUNCGWF4H2Y
                        Serial_5CG1247M00
                        Product_19X35AV
                        Fearture byte_3X476J6S6b7B7H7M7Q7W7m7saBapaqauawb8bUcAdUdpdqeMfAfPguhKhkjhk8mEmVmwnVng.Nt
                        Build Id_21WWCVCT601#SAK8#DAK8
                          840 g8
                          sno=5CG2227X2B
                          6050A321750-MB-A01
                          REBUILD FILE POWER ON ISSUE
                            Can someone help me?
                            Laptop EliteBook 840 G8.
                            I read your posts and the instructions on how to remove the password, and I did it... it's working. I was able to install Windows, etc. But now, every time it starts, the following error appears:
                            HP Endpoint Security Controller problem.
                            Attached are the BIOS and EC that I unlocked.
                            And maybe you can tell me a post to read and learn how to clean it
                            Thank you
                              Thank you
                                Now it show manufacturing programin mode - 30
                                it seems that dmi is missing. but in the HEX it show the data.
                                can you help me? thanks
                                  You can use HP Bios Config Utility to lock MPM or enter any missing DMI.
                                    Perfect, thank you, i enter all dmi data, use RCunlock. i look at some videos... and split de bios to fit the 16mb, and use partsurfer hp.
                                    Thank you
                                      Thank you for the bios.
                                        Hi! Can you please help me unlock SWAT and HP Endpoint Security Controller? Thank you.
                                        SN: 5CG1392PGH
                                          SN: 5CG1392PGH
                                          SWAT removed
