Originally posted by basalisco
View Post
Extract bios password from EliteBook 840 G8 Bios dump, possible?
Originally posted by skylinekiller View Post
I have the laptop disassembled and my questioned had asked if there is a programmer out there where I wouldn't have to remove the chip..
I created an adapter with a 3D printer, probe pogo pin, hot glue and jumper wire.
Everything worked and now that I have found all the information (feature byte, build ID and factory host based MAC address).
I installed the firmware from the HP driver page.
Originally posted by basalisco View Post
I'm interested, can I share the stl file?I'm interested, I was thinking about it too, can you share the stl file?
This is a prototype and was only tested on my mainboard.
[MOD EDIT] External link removed,added attachment to post
To flash, I used the official file "T76_01160000.bin" from HP's driver page.
https://ftp.hp.com/pub/softpaq/sp151...0/sp151275.exe
The Serial Number, Product Number, build_id and Feature Byte can be found on the inside of the cover.
The CT Number and MAC Address can be found under the memory module.Attached Files
In EasyEDA open source hardware lab, open source square pools all kinds of electrical design engineerings together to realize resource sharing easily.
Hello friends.
I have a problem with my hp 840 G8
After updating the bios it didn't start, it just kept flashing the side light. I went to check the main dump behind the card and it was corrupted when reading. How is this possible? Is it possible to recover the main dump? help me please?
HP EliteBook 840 G8
SN: BRJ146RKMZ
CT: BKFNA035WF638B
IEC P/N : 6037B0161911
MAINBOARD: CORVETE - 6050A3217501 - MB - A01 (A1) (1086) L2Attached Files
HP EliteBook 840 G8
SN: BRJ146RKMZ
CT: BKFNA035WF638B
Become a Badcaps supporter
Thanks to all supporters.
Originally posted by Muhammad Faizan View Postfix this error plz.
first boot press f10 reset bios to factory defaults and exit, 2nd boot reset security settings to defaults.
you can permanently disable absolute in BCU. Use BCU to fill these DMI info:
Serial Number: 5CG211478Z
Product #/SKU: 3K0M1UC#UUF
CT Number: PQSNL00WBGE77Z
Description: HP EliteBook 840 G8 Notebook
BuildID: 21WWCVET601#SUUF#DUUF
Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPguhKhkjhk8mEmwn7nVngpD.4g
MAC Address : 60:6D:3C:CB:E8:ADAttached Files
Originally posted by Edgars UK View PostHi everyone.
Please help remove password - clean my laptop bios.
Main and EC dumps are attached files.
Thanks in advance.
M/B CORVETTE-6050A3217501-MB-A01
Thanks in advance.
Thanks in advance.
Thanks for the warning - I understood and will write down the serial number from now on.
SN#5CG1468T1M
Thanks for the warning - I understood and will write down the serial number from now on.Attached Files
Hellp me elitebook 840 g8, Hello, can someone help me rebuild the main bios, I have received this device with another base case, from an elitebook 845 g8, for the same reason I do not have the original serial number, I only have the dump of the ec chip, the board has the corvette code 6050A3217501-MB- A01 the main bios comes empty....Attached Files
