hi i need hp elitebook 840 g8 both bios files with clear me main bios and ec bios
Extract bios password from EliteBook 840 G8 Bios dump, possible?
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
Originally posted by caprigtx View PostHi , Need help with unlock my Hp elitebook 840 G8 bios pw
Hp Elite book 840 G8
Sn : 5CG1417XJT
Become a Badcaps supporter
Thanks to all supporters.
Sn: 5CG1417XKB
Thx in AdvanceAttached Files
Hello. I need bios+ec for an 840 g8 computer. There is 5v and 3.3v, but the fan starts and stops once. The image does not appear. Can you help?
Serial Number : 5CG2275NVW
Product Number : 687L7AV
Description : HP EliteBook 840 G8build id: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAfuture byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdpdqfAfPgSguhKjhk8mEmwn7nVngpq.3B Attached Files
Originally posted by bykanovm View PostRe: Extract bios password from EliteBook 840 G8 Bios dump, possible?
Thank you. I already figured out the addresses in HEX and was able to remove the password from the EC bios file. Thank you for your fast reply
Originally posted by rex98 View PostRe: Extract bios password from EliteBook 840 G8 Bios dump, possible?
S\N 5CG2157WVT
flash only this EC 2nd chip. it will promt endpoint security controller just ignore it enter. it will disappear in next boot.
next time use any hex editor fill with ff in this offset 00037000 to 000379df
IF YOU HAVE MORE KNOWLEDGE ABOUT OTHER MODELS, I'M WILLING TO LEARN. 🤩🤩🤩🤩🤩🤩🤩🤩
Originally posted by jm801 View PostBuenas noches, me trajeron un HP Elitebook 840 G 8 que simplemente no se enciende, el bloqueo de mayúsculas parpadea, no sé si podría ayudarme a reparar el BIOS.
HP ELITEBOOK 840 G8
ID de producto 47F04UC#ABA
SN# 5CG1421MSYAttached Files
HP ELITEBOOK 840 G8
SN# 5CG1421MSY
Originally posted by lokmanolgun View PostHello.
endpoint security gives error. Can you fix this
840 g8
6050a3217501-mb-a01
Try this, post 1, 5 https://www.badcaps.net/forum/troubl...security-error
Good morning Gentlemen of great wisdom. I need your valuable help in the following case: I have an EliteBook 840 G8 computer that arrived with a password in the bios. The first mistake I make is not taking the backup of the 3 chips before starting to modify. I tried to remove the password by unlocking the EC and the device turned on once but still had the password. The Second time I tried to unlock the password both Main Bios and EC. From that moment the equipment tries to start in a loop without providing video. I have tried the bios backups that are on the Internet and the same thing, I am sure that there is no missing resistance nor is there any altered nearby component, I must also say that everything has been perfectly welded. As additional information, I must say that with my bios backups the computer does not beep for a ram memory error, but with a backup found on the internet it does beep for a ram error but it still continues in a loop without video.
HP EliteBook 840 G8, SN# 5CG1411K3R, Board CORVETTE-6050A3217501-MB-A01(A1) UMA HSN-I41C-4. The board is SRK1F (Core I7). I appreciate any help provided.
Additional addendum: I suspect that the bios of Core 5 and Core 7 SRK1F are different if they are on the same board.Attached Files
Originally posted by MICHAEL_2013 View PostGood morning Gentlemen of great wisdom. I need your valuable help in the following case: I have an EliteBook 840 G8 computer that arrived with a password in the bios. The first mistake I make is not taking the backup of the 3 chips before starting to modify. I tried to remove the password by unlocking the EC and the device turned on once but still had the password. The Second time I tried to unlock the password both Main Bios and EC. From that moment the equipment tries to start in a loop without providing video. I have tried the bios backups that are on the Internet and the same thing, I am sure that there is no missing resistance nor is there any altered nearby component, I must also say that everything has been perfectly welded. As additional information, I must say that with my bios backups the computer does not beep for a ram memory error, but with a backup found on the internet it does beep for a ram error but it still continues in a loop without video.
