unlock bios for dell latitude 3520
    Hi friends
    , Please help me to unlock this dump file. Dell Latitude 3520
    service tag
    GSV8WL3
    thanks in advance
      Originally posted by X-FILES View Post
      Hi friends
      service tag
      GSV8WL3
      thanks in advance
      Unlocked
      Become a Badcaps supporter
      Thanks to all supporters.
        Thank you very much
        you are a genius
          DELL LATITUDE 3520
          SERVICE TAG 157BKG3
          PLAESE HELP WITH THIS BIOS NO OLD DUMP
            Originally posted by azoozkkb View Post
            DELL LATITUDE 3520
            SERVICE TAG 157BKG3
            did you try some bios in this thread? if not what is the laptop issue?
              I tried but the problem is the bios dump should have service tag when i program bios the screen turn to color test so i should rebuild the bios
                Hi friends!
                ServiceTag
                H67QGL3
                  Can't anyone help me? Please help me make this laptop!
                    try...
                      Thank you very much
                      The laptop started working, special thanks again
                        Hi guys can you help remove password on this Dell Latitude 3520 motherboard 213047-1 Cyborg L15 MB TGL , S/N 1P2YGL3, Thanks
                          Try this....
                            Thank you bro I have tried your file Struart but the machine is showing red gren blue colors like screen test and it will restart and do samething fan spinning fast but let me try another eeprom first
                              SMDFlea commented
                              Editing a comment
                              Check your soldering first
                            Kodza
                            If still no go try this one.... maybe i make mistake.
                              Originally posted by struart View Post
                              Kodza
                              Thank you for your helpbut I don't think it's your file which got problem because I have realised that when I power on the laptop there is no display and after a while it will start blinking 6 white and 3 amber blinks to show bios problem and then start the screen test sequence. So after I tried your patched file I also changed the bios and it did the same and then I put back the original file and still it's doing the same. I have checked if maybe I knocked some resistor and soldering but all looks fine. So I was thinking if you could help make a clean bios file from my bios file and try again. Thanks
                                I am trying clean me file but it's still doing what I mensioned above, so I believe I might need to reconstruct the bios from exe file but I am unable to do it so I need help to do that from good people of this forum.The laptop is Dell Latitude 3520 Service Tag 1P2YGL3, mainboard 213047-1 Cyborg L15 MB TGL.
                                  try this new bios.
                                  1st boot, press F2, write service tag, disable Absolute, save, restart. 2nd boot press Alt+F to exit manufacturing mode
                                    Originally posted by Rexer Anthony View Post
                                    try this new bios.
                                    Thank you Rex but it's not displaying no fan spin, when I put charger the laptop comes on and after some seconds it goes off if you try to press the power button it does not respond but when I remove charger and put back it does the same again, no display no backlight
                                      Send to you, try
                                        Originally posted by minhdigital View Post
                                        Send to you, try
                                        Thank you Minhdigital I will try it tommorrow when I am at work and let you know the result
