HP BIOS unlock tool
    Funny thing before I zip the file they are both 16.0 MB (16,777,216 bytes)
    Why would this be?
    I've read alot on this forum today and not sure to install a new bios and then try to go trough the process of installing all bios information. Not sure its a little more than I can understand at this point.
      Why would this be?
      Because it contains mostly FF characters.
      Become a Badcaps supporter
      Thanks to all supporters.
        Thank You for the help
        So my orig bios was verified and still bad.
        Any suggestions on where to go from here?
          Now you have to restore bios and ec by getting the files in this topic,
          https://www.badcaps.net/forum/troubl...itebook-840-g2
            Hello all. I followed the link as best I could. Flashed the bios again. Laptop is fully functional but very slow startup and HP logo sign. I am not sure what file to use if EC needs to be repaired. All laptop info looks correct in bios. I assume that is ME area? I'm confused as this is a bin right from here and every comment says no issues
            Any help would be great.
              Upload main bios.
                This is what I used from post 19
                  HP EliteBook 840 G2 Base Model Notebook PC
                    Thank You hoaca388 for all the help. It worked great. Laptop is all working. I've lost some bios information but I will search out the HP tools on this site to help input some of the lost info. I know I came across a bunch of info.
                      Thank You ))))
                        Hello, I need to remove the password on a Elitebook 840 G5.
                        RC unlocker did not work because it is a 32MB EEPROM...
                        Prod ID 2FA66AV
                        SN 5CG9236L4L
                        motherboard C0796B10WEA rev1.11 (Full Intel, no dedicaced GPU)
                        ThanX!
                          Prod ID 2FA66AV
                          SN 5CG9236L4L
                          ThanX!
                          HP EliteBook 840 G5
                          Serial_5CG9236L4L
                          Product_2FA66AV
                          Fearture byte_3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqhKhkjh.F5
                          Build Id_17WWCSCT601#SABF#DABF
                            Originally posted by hoaca388 View Post
                            HP EliteBook 840 G5
                            Serial_5CG9236L4L
                            Product_2FA66AV
                            yhank you for your help but I have a problem.
                            the keyboard is out of order (I did not know that "detail") so I did desold and resold twice but at the second time, I swipe one or two components (I'm sure for one, this circle alone, next the white arrow).
                            I think it was resistors.
                            Do you have the resistance of them?
                            EDIT> I found what I need on the forum :-)
                            Very nice forum here!
                              Use 4.7K ohm
                                Hi
                                I have an HP 8470p with W25Q128BVFG bios chip. Is there a way to reset the password without dumping the chip using a programmer?
                                Also all the instructions are for the 8 pins chips. This 16 pins chip is a bit different. Would you please help me here? thank you
                                  Originally posted by Hiva Amiri View Post
                                  Hi
                                  No.
                                  You can buy a SOP16 clip to go with your programmer, or if you have the tools to desolder the chip get a SOP16 test socket or adapter board
                                    Hello. i need unlock bios for HP 850 g8.
                                    SN# 5CG1351RTT
                                      SN# 5CG1351RTT
                                      post both file
