Dell Inspiron 3482/3582 bios password
    Re: Dell Inspiron 3582 bios password
    Originally posted by teqcom View Post
    Inspiron 3482
    Service Tag: HXFYZX2
    Express Service Code: 39027510614
    plz Remove the password
    Pssword :- KABIRJUTT
      thx u so much
        Originally posted by Kodza View Post
        Thank you Onizzbox it worked. I am grateful
        how get that hash code
          Originally posted by SMDFlea View Post
          post your backup
          please tell me how to find passwords from the backup bios...
            I've a Dell Inspiron 15 3505 with following Codes after three times wrong password:
            System Disable [2719A0F77CE22422]
            Service Tag [HV5NXF3]
            Please, can you give me the admin password?
            Do you need a dump of the BIOS or other informations?
            Regards
            Oliver
              Regards
              Oliver
              Yes , upload your bios dump here.
              Become a Badcaps supporter
              Thanks to all supporters.​
                Well, I've looked around, but found no tool or instruction to dump the BIOS.
                Do you have a link or tool to dump with Windows 10?
                  do I need an external piece of hardware (e.g. programmer) to dump the BIOS or can I do it with software under Windows or Linux?
                    Okay, now I'm able to generate a master password with the System Disable & Service Tag.
                    I now can unlock the BIOS settings with this master password and CTRL+Enter, but how can I reset/ change the admin password?
                    I tried in the admin pw section the generated master pw in the first field (old pw) and left the two other fields (new pw) blank, but that doesn't work, it says "Incorrect pw".
                    Has anyone a clue how I can disable/ change the admin pw?
                      @pmax
                      This CTRL-ENTER-ENTER keystroke after the password only applied to laptops with a suffix (xxxxxxx-8FC8 for example), until Dell also required it in some laptops using System Disable 16-Hex algorithm, on which only the Password+ENTER was needed at first and then in some models you needed the CTRL-ENTER-ENTER to properly delete the system passwords, otherwise the password would remain SET upon the automatic system reboot if just doing Password+ENTER until the proper CTRL-ENTER-ENTER keystroke was performed in certain models.
                        Hi all. Please tell me bios password for inspiron 3582
                        Service Tag(S/N) 7KYYF13
                        Express Service code 16505512599
                          hello
                          plss i need the bios file for edi55 la g094p dell inspiron15
                          The laptop turns on but the hard drive doesnot show all basic checking has been done .
                          if anybody can help me ,
                            my service tag is G7HZ1W2.
                            Can't read the original chip.
                              Inspiron 3482
                              Service Tag: CHMYF13
                                Originally posted by Stunt View Post
                                Inspiron 3482
                                Pass = 1234567890
                                  Inspiron 3482
                                  User Password: 1234567890
                                  Admin Password: 1234567890
                                    Thanks man it worked like charm
                                      Re: Dell Inspiron 3482/3582 bios password
                                      edi55 la-g094p bios passord locked..pls unlock this
                                      service tag - DqQZ0DX2
                                        Upload your bios backup.
                                          here is my file
