---------------------------------------------------------------------------------------------------------------------------------------------------------- All donations to Badcaps are welcome. Become a Badcaps supporter >>>>>click on this link to donate <<<<< Thanks to all supporters.​ ----------------------------------------------------------------------------------------------------------------------------------------------------------
I have a last question if you don't mind!
Is it going to be a problem if I do a Bios Update via Windows, to the latest version after the installation of this unlocked version?
Thank you very much Vesko356!
Cheers
No, it won't be a problem, you can update to any version you want, including the latest one.
The error is shown on the screen - invalid password. You must input the correct (bios) password, or better remove the password, then update the bios. If you like afterwards you can set the admin password again.
After the Bios Unlock I've asked you if I could update bios version afterwards to the latest one... You said yes there would be no problem and after that I have downloaded the latest one and during update process, it gave me that error! Isn't supposed to be without password?!
Enter the bios, remove the password if you set any, if you didn't set the password everything should be OK (admin password must be cleared with the unlocked bios), check the Service Tag field - must not be empty, if it is ,the STag must be inputted and saved.
At first boot press F2, write the service tag, save & restart. After that at the second boot press Alt+F to exit manufacturing mode. And the fan will slow down.
Hi everybody. Please help me BIOS has late display problem. I have worked with FIT but the problem has not improved. I have flashed many other dump files but not working. With other LA-g871P systems FIT works perfectly.
Hello i just received the Dell Latitude 7400 with a password.
i tried it with the bios.bin you posted. it goes well , i edit the same service tag that was there before , i came out of manufacturing mode.
after a half hour of test; sometimes the pc get froze .
ii want handle it , have i done something wrong by editing the same service tag?
allow me please to upload my own backup (with password )
thx u so much
Hello here is your unlocked file, always use your original dump to avoid any problems.
You must attach files directly to your post instead of linking to external websites.
remove password please Dell Latitude 7400 EDC40 LA-G871P
1st boot, press F2, write service tag, disable Absolute, save, restart. 2nd boot press Alt+F to exit manufacturing mode.Good luck.
All donations to badcaps are welcome,see the donate button at the bottom of the page,or click on this link to donate via PayPal. Every donation made will go towards server fees and maintenance costs.
