BBS MOD MxP APPLE BLACK BOARD SERIALIZER
    Re: BBS MOD MxP APPLE BLACK BOARD SERIALIZER
    Originally posted by Maxpower3 View Post
    *********** BLACK BOARD SERIALIZER ***********
    Blank Board Serializer is mod by MxP !! Enjoy !!!
    Setting serial number is too easy
    " Only for all Mac models 2009 to 2017 "
    This USB tool helps to:
    Change the Serial Number (SSN) or add a new Serial Number.
    It supports all type of Macs including MacBook, MacBook Pro, MacBook Air, iMac, Mac mini and Mac Pro (2009 to 2017).
    * Use RUFUS to create USB key with .img
    ** The process is as simple as booting the Mac from the USB tool, type a new serial number and confirm.
    --------------------------- WARNING--------------------------------------
    Some letters are prohibited from origin program by Apple "AEIOUBSZ". (look pics)
    I authorized them in this version for test.
    Don't Use if you don't know
    This is not a crack of MacUnlock version, just this inspired me and I searched
    Just need a little usb key
    Archive Size: 389*Mo /.img Size: 494*Mo
      Rufus for Mac Alternative: balenaEtcher
        CAN YOU SHARE THE FILE .IMG
          It's in post #2
            Does it remove Mdm Lock permanently?
              BBS bootable usb which models compatible with year.
              please tell me. Thanks
                Read post 1
                  how to make bootable usb with rufus? the file in post2 is .zip,,
                    Dear Sir how to create bootable USB, i download this file
                    (MDM2009-2017.zip) but its not supported on rufus, even i change to IMG, but still not support. can you help me this this please
                      Extract rar and try like this with img
                      Click image for larger version  Name:	Nouveau Image bitmap.bmp Views:	0 Size:	1.45 MB ID:	3225816
                        brother this model supported?, A1989 ?
                          no, I don't believe
                            no, I don't believe
                            and dear thanks for help, i do with hardware via change SN on bios chip, one more help, i want to change SN Macbook M1, the serial inside in EMMC (Nand Chip)? becuase i find on bios chip not found in Bios chip.
                              Can you tall me how i can use this, i just copy this files to my usb flash and it works with 90% of macbooks but not all, what i should do?
                                Ok, friend, I'll try it and tell you, thanks for the contribution.
                                    I have a 2020 MacBook Air (M1 chip) which does not have a serial number and has a loop in 'Diagnostics Loader', is there anything that can be done?
                                      This software won't help sadly
                                        is it possible to remove the iCloud activation lock on an a1708 MacBook with the serializer?
                                        After change the serialnumerb it should be possible to activate or?
                                        best regards
                                          Yes, it will work
